Old 10-03-2008, 10:28 PM   #1
Ricks1971
Ricks1971's Avatar
van tilt question?
Hey guys, I have a van tilt from a 78 chevy van and my question is that the tilt has a button on the end of the turn signal lever. Will this titl work in a 68 chevy pickup? thanks Rick
Ricks1971 is offline   Reply With Quote
Old 10-03-2008, 11:13 PM   #2
Somecallmejoe
Re: van tilt question?
It will work. You just need to shorten the shaft between the steering box and the column a little and buy the adapter harness so it will plug into your truck. The button is for cruise control. If you don't need cruise control you can just change the turn signal lever to a regular one. There should be a a single wire coming out of the column that goes to the lever with the button. All you have to do is don't hook it up. Hope this helps.
Somecallmejoe is offline   Reply With Quote
Old 10-04-2008, 05:59 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, it's a tripple wire with a single plug.
Old 10-04-2008, 11:00 AM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yes it will work fine, the button is just for cruise control!!! Just need the adapter for the plug under the dash!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
