Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 10-05-2008, 06:04 PM   #2
JimKshortstep4x4
Re: Hotwire for wiper/washer pump
The three wires hooked to the wiper button are all used for grounding. The wiper and washer pump are powered off of an ignition source so when the key is on the power is on.
To use the switch with your pump it would be a simple matter of running a hot wire off of the fuse panel. You can plug it into the "Unfused Ignition"
section and set up an inline fuse if you want to fuse it.
Then you could extend the wire for the washer pump switch to the new pump so that when you pushed the button the pump would work.
There are two wires on your original pump, 1 is power, (yellow, I believe ) and the other is the wire that you want to extend to your new pump.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
JimKshortstep4x4 is offline
