Old 10-05-2008, 01:55 PM   #1
mole2000
mole2000's Avatar
up control arm shaft crossmember bolt
one thing after another it seems... when i removed the nuts holding the up control shaft in place, the threads were damaged. Is that bolt removable? some drawings from lmc catalog appear that it's pressed in or something? #8 in the image...
mole2000 is offline   Reply With Quote
Old 10-05-2008, 04:13 PM   #2
hotrodxy
hotrodxy's Avatar
Re: up control arm shaft crossmember bolt
its like replacing the studs on your axle or hub, hit it with a big hammer to get it out. then use a nut and washers to pull the new one in.
1967 LWB 4speed-current project
1970 LWB 3 speed -stolen
1980 Z28 - sold
1968 Barracuda Big block- sold
1969 Firebird 400/400-sold
hotrodxy is offline   Reply With Quote
Old 10-05-2008, 04:33 PM   #3
cstm68
cstm68's Avatar
thats how i did mine last weekend
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 10-05-2008, 06:12 PM   #4
mole2000
mole2000's Avatar
Thanks everyone. This board is great. Although I've worked on vehicles my whole life, this forum gives me the support to try stuff I never have and share what I do know.
Old 10-05-2008, 07:39 PM   #5
cobrajet21
cobrajet21's Avatar
I bought the LMC bolts. Check out my post a few days ago. I'm now looking for another crossmember.
http://67-72chevytrucks.com/vboard/s...d.php?t=308904
cobrajet21 is offline   Reply With Quote
Old 10-05-2008, 10:09 PM   #6
mole2000
mole2000's Avatar
what happened cobrajet21? Did LMC send an incorrect bolt that caused a problem such that it ruined the opening for the correct bolt? I imagine that if you put in a too large bolt, that would make it very difficult for the correct one, if it was a smaller diameter... that sux. i havent been all that satisfied with my limited purchases from lmc, but that would turn me off them for good.
Old 10-05-2008, 11:02 PM   #7
cobrajet21
cobrajet21's Avatar
the bolt in the pic is what they said was the replacement. the threads are the same the length is the same but the spline area is larger than the stock bolt and very hard to press in. it makes the hole too large for a stock bolt to go back into. some people on here were concerned that the smaller head on the lmc bolt might pull through after awhile and that got me nervous so i am going to get another crossmember and buy the correct bolts from performance online. it might not be a problem but i don't know.
Old 10-07-2008, 09:37 AM   #8
cobrajet21
cobrajet21's Avatar
sorry, the correct bolt is at classicparts.com not performanceonline.
Old 10-07-2008, 12:06 PM   #9
mole2000
mole2000's Avatar
my local chevy dealer still carried the bolt for about $4...
