09-24-2008, 11:09 PM | #1 |
84 Suburban Heater Issues
I've been doing a little work on my brother's 84 3/4 ton 2wd Burb. The heater isn't working quite right and I'm not quite sure what to take apart. The problem I have is when the control is set to defrost, air is still blowing out the vents in the dash and a little is blowing out the defroster vents. It is an AC truck and I'm pretty sure it is getting good vacuum. Where is the part I need to check? I tried searching, but didn't really find anything. Any help will be greatly appreciated. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
10-04-2008, 10:48 AM | #2 |
Member Dude
Re: 84 Suburban Heater Issues
probably the cable/wire that changes the direction of the air in the heater/cooler box under the dash
well thats if its anything like mine Last edited by eaglelox; 10-04-2008 at 11:55 AM. |
10-04-2008, 05:38 PM | #3 |
Like just stated, the cable/wire would be good to check. I changed out my heater core on my '89 suburban a few weeks ago and I discovered a door inside the HVAC box that had a broken plastic part on it. As a result, the door would not close all the way. My A/C never seemed to get as cool as you would think possible and I remember my dad theorizing one of the doors might be malfunctioning and allowing the A/C air to get 'tempered" from hot air from the heater core. Sure enough, this was exactly what had been happening for a long time. Anyway, instead of buying another piece of plastic from the dealer(bad design), I just bent some flat metal in a hat shape(the exact size of the plastic part) and attached it to the metal door. Now when the door is pushed open or closed, it's metal to metal, instead of metal to plastic. While I was in there, I noticed some of the ductwork didn't seem to line up good(leaving air to escape), so I taped several leaks with an insulation type tape when I reassembled everything. My A/C and heater work better than ever, colder, hotter and with better air flow. I should have taken a picture of the part I made and where it goes, but I have already closed it all up.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
10-04-2008, 10:07 PM | #4 | |
In the Forgotten far North.
(Just kidding)
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
10-05-2008, 06:49 PM | #5 |
Thanks for all the help. A friend of mine was in the process of replacing his heater core (on an 83 Blazer) and I got to take a look at his heater when it was out of the truck. I now have a better idea of what I need to do. Thanks again.
10-07-2008, 12:23 PM | #6 |
Yeah, sorry about that. Speaking of arse, taking out those factory nuts and bolts that hold that HVAC box together was a pain in the arse. I got the nuts off, but couldn't get the bolts to back out, due to the factory retaining clips. There's probably an easier way, but I ended up sawing off the bolt heads(firewall side) with a diamond cut-off wheel on a dremel tool. When I put the HVAC box back together I used new nuts and bolts and through bolted the whole assembly(sans clips of any kind) to make it easier to take apart next time. One tip, I strongly recommend taking out the passenger side fender well. It will make access to the firewall side nuts much easier.
10-07-2008, 10:15 PM | #7 |
Member Dude
sometimes if you catch the clip with a screwdriver you can lift it to catch the threads of the screw. i would put a small wedge or screwdriver in and go around to other side. hehehe, to late now.
