bags
Hey what all is entailed in baggin a truck? I was thinkin of dropping my truck, a 67 coils all the way around., with a drop spring kit. I guess I know the basics of it but if someone could really just lay it out for me and let me know of any little things that are often over looked I would really appreciate it. Thanks alot
Progress = 0%
Parts you'll need (this is very general):
Bags, tanks, air line, fittings, valves, switches.... The rear bags are easy, as they can be installed in the stock coils spring location. The fronts required some bracketry, but also mount in the stock coil spring location. Depending on how low you want to go, a rear c-notch may be needed. Check out the pics on my web site...... might give you a better idea.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Hey Slammed..... cool website. I thought of trying something like the radio delete plate but didn't want to take off the trim plate of my radio (I'm working out alternatives now). Very smooth install though.
Project92 SWB stepside
Man that is a sweet truck!!! I have had my 83 tore apart for 2 1/2 yrs and am currently trying to bolt the chassis back together. I cant wait!! That web page gives me inspiration!!!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
