Old 02-19-2003, 01:11 AM   #1
67swbc10
Coming Apart
On one of my cabs the seem between the floor pan and the upper floor below the dash has seperated. Does this happen very often or not? Is there a way i can pull it back together and weld it ba ck if so how would i pull it back together.
Mario
1967 Chevy SWB
67swbc10 is offline   Reply With Quote
Old 02-19-2003, 01:45 AM   #2
69 Short Fleet
Hey Mario: Ive never saw or heard problems in the area you described, but I would remove all the paint and factory caulking around the seem area that has seperated down to the metal weld it grind it and do the primer & paint thing again, I would be a little suspicious as to why it came apart in the first place and inspect it on the outside of the cab and make sure that no water or moisture can get in the area and cause problems later. Doug
69 Short Fleet is offline   Reply With Quote
Old 02-20-2003, 01:37 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey Mario, mine's doing the same thing. I haven't gotten around to fixing it yet but I'm going to pull it back together with vicegrips and weld it..
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
