Old 10-11-2008, 02:38 PM   #1
Riveted1
Tasty Cakes!
Riveted1's Avatar
Another wire I need help identifying
Replacing the beaten up engine harness in my 67. My truck has HEI now, so I ordered a M&H harness w/the HEI conversion built in. Trying to figure out what the pink/yellow and the blue wires are. I'm assuming the pink/yellow is the power for the HEI. But what is the blue? Is that a tach wire maybe? Or somewhere I saw a blue wire for an electronic oil pressure gauge? I can double check w/the meter here in a while, but thought I'd post and see if anyone knows for sure before I burn something up!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 10-11-2008, 05:17 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Another wire I need help identifying
I'm guessing maybe electric choke. I ordered the same harness, but had to send it back for the electric choke wire.....
The oil pressure wire has a rubber boot on it.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-11-2008, 09:10 PM   #3
ERASER5
ERASER5's Avatar
Why is there a yellow wire on your HEI power wire? With HEI you no longer should have a yellow wire going to the starter.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-11-2008, 09:55 PM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
Even with the old setup, I still have a yellow wire going to the starter. And I'm not sure if that even is the HEI wire, although everything else is accounted for, so it pretty much has to be..... Didn't have time to meter it tonight, will check it tomorrow and see.
S/T, I guess the blue one could be for electric choke. It can't go too far from the other wire, so that would make sense IF the other one is actually the HEI wire.
Old 10-11-2008, 10:06 PM   #5
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Another wire I need help identifying
Yellow and pink are the HEI wires, and the blue is for the oil pressure sender, if you have the light only. I know this because I bought the same harness a couple of years ago, it all plugged in and has worked great!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-11-2008, 10:09 PM   #6
Firefighter
ERASER5 I have the same harness and my yellow wire is hooked up to the starter, never have had any problems at all with it hooked up like this.
Yellville, Ar. USA
Old 10-11-2008, 10:13 PM   #7
vectorit
What?
vectorit's Avatar
Call M&H and ask for Darren, then tell him Chris with the 68 Suburban told you to call... Even thought M&H pissed me off, Darren worked with me for hours over the phone testing each circuit. He will explain what each and every wire is for you, plus he is a very patient guy that put up with me so that says a lot.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-12-2008, 07:28 PM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
Sweet! That's exactly what I needed!
Old 10-13-2008, 09:02 AM   #9
Firefighter
Talking Re: Another wire I need help identifying
anytime!!!
Yellville, Ar. USA
Old 10-13-2008, 01:04 PM   #10
ERASER5
ERASER5's Avatar
Sure, you can keep the yellow wire hooked to the starter. It doesn't hurt anything. That is how the original wiring is.
However, the original coil wire-to-firewall was a resistance wire that cut the voltage to 6 volts. The yellow wire to the starter gave you a full 12 volts at start up for better spark until the starter is released.
A proper HEI power source will NOT be a resistance wire. It will be a normal wire supplying 12 volts to the coil at all times(when the key is on or starting). The yellow wire to the starter is redundant and not necessary. Check any of the FAQs on HEI conversion.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
