Old 10-09-2008, 10:28 AM   #1
forsale
New cab mounts
Has anyone used the Energy Suspension cab mounts on a 67? I'm having a hell on a time alighning sheet metal and I think it's my mounts screwing me up.
Is there an advantage to using some from ECC or LMC?
forsale is offline   Reply With Quote
Old 10-09-2008, 02:47 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: New cab mounts
forsale, check your radiator core support mounts.Most cab mount kits come with the later 69-72 core support mounts.They are different IIRC taller than the 67-68.They will cause alignment nightmares.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-11-2008, 06:33 AM   #3
GMCPaul
Re: New cab mounts
PanelDeland said it right the Energy Susp. kit comes with 69-72 radiator core support mounts which are 1 1/8" to thick to use on 67&68 trucks, this will cause to tight a gap at top of fender, to wide a gap at bottom rear of fender and cause body line from door to fender to be off. In order to solve this you'll need to pick up 67-68 core support mounts. Ours can be found here
http://www.gmcpauls.com/rubber_&_weather_strip_21.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 10-11-2008, 06:51 AM   #4
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: New cab mounts
I got my kit from Wes at Classic Heartbeat......It came complete with everything...And Wes is one helluva a guy to deal with.........
bad6772 is offline   Reply With Quote
Old 10-11-2008, 11:24 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: New cab mounts
Thank you for the compliment bad6772. I appriciate that.
I would toss the Energy Suspention Cab Mounts in the trash. There is no give in them what so ever. Urithane body mounts are hard on vehicles with flexible frames, because they do not give when your frame flexes with the road conditions. They also do not have any advantages over their rubber counterparts. You just as well weld your cab to the frame. I have had many customers here replacing their poly body munts with rubber because of dammage they caused. Remember GM used rubber there for a reason, and the reasone is they absorb shock, give when needed to, and absorb vibrations. Urithane does none of this. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-11-2008, 02:41 PM   #6
forsale
Re: New cab mounts
Good info. Are the mounts on the 67-68 somwhere around a 1/4" thick? I think I have them I just thought they were missing the mount. So I did put in the 69 mount and they are throwing everything off. Thanks for the help guys.
Old 10-12-2008, 07:13 AM   #7
GMCPaul
Re: New cab mounts
forsale yes you are correct the 60-68 radiator core support rubber mounts are approx. 1/4" thick.
GMCPaul
