Old 02-18-2003, 11:06 PM   #1
Jason71k10
ready for reassembly
Jason71k10's Avatar
lift blocks or new springs?
Just wondering if you guys have had any bad experiences with lift blocks on your rear springs?? My springs are fine, so i figured i could save some money by going with blocks and just put new springs on the front.
it's a 71 4x4
I know this would better suit the 4x4 forum, but they don't seem to get much response when posted there........Any thoughts??
thanks
Jason71k10 is offline   Reply With Quote
Old 02-18-2003, 11:08 PM   #2
mkmiller1
mkmiller1's Avatar
How much lift are you going for?
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 02-18-2003, 11:10 PM   #3
Jason71k10
Jason71k10's Avatar
oh, sorry, i guess i should've said that. About 3 inches
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Old 02-19-2003, 01:18 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
You could also think about an add a leaf...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 02-19-2003, 10:55 AM   #5
Jason71k10
Jason71k10's Avatar
Add a leaf in the back you mean?? I've had experience with add-a-leaves in the past on my Jeep YJ. I wasn't happy with the lift at all !! In sank to nearly stock height again and made the ride even worse than it was before! I think i'll either go with blocks to maintain the ride, or new spring packs.......no A-a-L's, but thanks for the suggestion
Old 02-19-2003, 11:16 AM   #6
crazy longhorn
Fabricate till you "puke"
A 2 1/2-3 " block should be fine in the rear.....blocks are a no no up front tho.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-19-2003, 12:05 PM   #7
Church
Carolina Classic Trucks
Church's Avatar
If you are only going 3", go with the block in the rear. Like crazy said, blocks are a no no up front!! If you go with springs in the rear it will cost more money and will sacrifice a little of the ride quality.
Church is offline   Reply With Quote
Old 02-19-2003, 12:44 PM   #8
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
How much 4x4ing will you be doing. If you're looking for flex, go with new springs. If you just looking to clears some tires and save some $, go with blocks.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
