www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Calling all fuel injection gurus
Kenny, You got a bad ground somewhere. The ECM2 lead should be pink/black.
Are you using nothing from the ECM except the fuel pump?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Kenny,
The ECM only turns on the fuel pump relay for a few seconds when you first turn on the key. This is only to prime the fuel line and provide fuel pressure for start up. Once the engine starts, the oil pressure switch is what is powering the fuel pump circuit. Do you still have the oil pressure switch hooked up? Is the fuse that is blowing the 10A ECM_B fuse shown on this diagram? As for going fuel injection, the factory 454 TBI system is barely good enough for a 260HP stock motor. I think you have a pretty healthy cam, and are probably about double that horsepower. So I would be looking for a multi-port injection setup. You can get an intake manifold and fuel rails from Edelbrock and an aftermarket ECM from someplace like FAST. Then all you need to do is build the wire harness.
- Greg |
#3 | |
Navy Radioman Veteran
All I have to do is build the harness - haaaa you make it sound easy!!! lol Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 10-13-2008 at 11:31 PM. |
#4 | |
I started from the bottom up and was reading Gregs reply and didn't answer yours. I'll check my grounds! Thanks! Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 10-14-2008 at 12:28 AM. |
