Help on lowering coils to fit 20" rim
I need a set of front coils to lower my truck as low as possible. I will be running a 2 1/2" drop spindle with 20"/8.5" rim and a tire 255/35/20 height of 27" total. Does anyone know if I can run a 2" drop coil and have no rubbing issue's?
72 Pick Up Last edited by 72 Pick Up; 10-15-2008 at 03:09 PM. |
Re: Help on lowering coils to fit 20" rim
im running 20x9.5 wheels with 2 1/2 drop spindals and 2 inch coils. it does not rub but it comes close im shure it would if i hit a bump fast enough,
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Thank for the info.
72 Pick Up |
67-72 parts collector,…
![]() Join Date: Nov 2002
Everything depends on the "backspacing" of the wheels. They must tuck inside the fenders to work. Too low,... and they'll rub the inner fenders.
The backspacing on the rim is 5"
72 Pick Up |
![]() Join Date: Apr 2004
have you thought about bagging it?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Yes,It is my daily driver
72 Pick Up |
