shaving firewall qustions
quick question i got my sheet-metal/ body guy starting on customizing my cab i'm working on a 69 c-10 my question is i don't know weather to go with a a firewall kit from direct sheet metal which has five inch set back and would be nice since i'm running a big block, i could shave the original firewall and also another question is what are you guys doing for mounting the e brake assembly and also the accelerator pedal and also how are you guys running your wiring, i have to make some decisions quick my cab is almost back from being blasted if you guys could answer my questions i would appreciate also if you guys could post some pics i would appreciate
Re: shaving firewall qustions
There are a few things that are just going to almost have to come through the firewall.
I'm running the stock 69-72 ebrake setup. I have a small hole above where the stock wiring harness was for some of the wires, and another hole down lower kinda behind the cab frame for the rest. I also left the hole for the washer lines (maybe I should shave that....don't know) I used some sheet metal pieces from ebay (the seller is also a member on here....infanity or something like that). I'm using a drive by wire gas pedal....so I filled that hole too. ![]() ![]()
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 10-16-2008 at 12:49 AM. |
Everything was shaved on mine except for the wire harness hole,brake booster hole & steering column....EVERYTHING ELSE is gone...On my pict here you can see every hole that was filled, I did not put the emergency brake stuff as florida is flat and I dont need it or want it, speedometer cable is thru the floor. if you notice we also did the right side of the firewall curve to match the left side, our only mistake was not shaving the lip accross the top of it but it still looks terrific...We even shaved and filled the inside of the fenders just leaving the holes for the hood hinges..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 10-16-2008 at 06:55 AM. |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
