Old 10-15-2008, 09:02 PM   #1
Hawker7
Head Removal
I'm taking apart my 350 but can not get one of the heads off. The passenger side came right off, but the drivers side seems stuck on the number one piston area where the block and head meet. I have tried tapping/pulling the head off but it won't budge. We even took the crank out and removed the number one piston and tried tapping the head with a piece of wood but it will not come off. Anyone else have any problems getting their heads off?
Hawker7 is offline   Reply With Quote
Old 10-15-2008, 09:05 PM   #2
Psycho71
Psycho71's Avatar
Re: Head Removal
I'm sure you've triple checked this, but I gotta ask......You sure you got ALL the bolts out?
Don't get mad, no offense intended, just had to ask.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 10-15-2008, 09:06 PM   #3
Hawker7
Re: Head Removal
yep, got all 16 out with no issues.
Old 10-15-2008, 11:24 PM   #4
corn
Re: Head Removal
Big screwdriver & a deadblow. Aim the screwdriver down in the front or rear of the motor, between the head & the block & use your imagination from there. Repeat if necessary...
corn is offline   Reply With Quote
Old 10-15-2008, 11:48 PM   #5
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Re: Head Removal
If the screw driver is used be careful not to gall the deck surfaces. I'm a big fan of the pry bar in the intake ports pulling toward you standing on the exhaust side.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 10-16-2008, 12:22 AM   #6
mr48chev
mr48chev's Avatar
Re: Head Removal
A small block Chev has 17 head bolts http://boxwrench.net/specs/chevy_sb.htm Scroll down.
Take one more look and make sure each and every head bolt hole is empty and then do as Corn and or Primered Junk suggested.
e
I went out and double checked in my favorite old shop manual and a small block Chevy does have 17 head bolts.
I have actually seen small block heads that were broken along the bottom bolt row when someone used a big prybar to get the head loose and broke it along the whole row of bolts
Old 10-16-2008, 06:55 AM   #7
Hawker7
Re: Head Removal
wow, I will have to double check and make sure I'm not missing a bolt now. Had no idea there were 17 bolts..That might have saved me from a bigger problem
Old 10-16-2008, 07:37 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Head Removal
look here
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-16-2008, 09:13 AM   #9
Hawker7
Re: Head Removal
yep, that was the problem. I have no idea how I mis counted on the other head. I thought there was only 16...comes off easy with all the bolts out
