Old 10-15-2008, 03:09 PM   #1
youngin'
84' to 89' Face Lift....
If I were to do the face lift like to an 89' Suburban, what will I need to change? I'm tracking that I'll need the grille, headlight doors, and headlights. But I was wondering if I could get some clarification into whether or not I would need a new radiator support, wiring harness, fenders, hood etc. Also, if I were to try and make my crew have p/w, p/l how do we do that also? Thanks.
youngin' is offline   Reply With Quote
Old 10-15-2008, 05:25 PM   #2
74 C-30
Dually Pride
74 C-30's Avatar
Re: 84' to 89' Face Lift....
yes you need a radiator support and i dont believe you need to change the fenders and hood. the wiring can be modified easy enough
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 10-15-2008, 06:33 PM   #3
youngin'
How hard is it t swap out the radiator support? Is it just a matter or loosening and tightening some bolts or is it more along the lines of hacking and welding???
Old 10-15-2008, 06:43 PM   #4
Square84
I don't think these pills work
Square84's Avatar
all bolts
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 10-15-2008, 06:45 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
unbolt all the bolts to the support, unbolt the 2 radiator mounts loosen the fenders and pull it out. It isn't a cake walk getting the new on in, but it can be done. GMChemist did this to his.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-16-2008, 01:25 AM   #6
youngin'
Sounds great, Thanks!!!
Old 10-16-2008, 02:11 AM   #7
youngin'
1 more thing, does anyone have pictures or know of a walk-through that shows all the steps.
Old 10-16-2008, 11:35 AM   #8
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Talking Re: 84' to 89' Face Lift....
I was going to do the same thing, and aquired all the parts. Mine was going from a 78 to an 89, and for anyone interested in doing a conversion like that you will also need the wiper transmission assy. as it has longer shafts for the wiper arms to connect to. It will require drilling a new mounting hole. You will also need the plastic apron that goes below the windshield as the 73-80 style hood is different than the 81 and newer.
Lastly, for the early conversion, you will need to locate and drill a hole on top of the firewall to properly mount the fenders, I think the article below shows that in detail.
There is an article here that shows most of what you need to consider
http://coloradok5.com/grilleswap.shtml
It's not hard at all, just take your time. As for the headlight wiring, if you don't have it, you can use either the factory one from a 89-91 Blazer or Suburban, or the same one is used by the van's that have the 4 light setup..
Hope it helps,
Drew
Run down on parts for a 73-80 to a 89 Burb conversion.
  • New 81 stlye front fenders w/inners
  • Hood for 81 on style
  • Core support specific to the quad headlight style
  • Hood hinges
  • Wiper transmission assembly (I also grabbed a newer wiper motor)
  • Plastic cowl panel
  • headlights
  • directional/parking light lenses
  • grill assy
  • all mounting hardware for core support to include grill mounting tabs, screws, etc..
  • wiring harness from firewall plug to lights
  • battery tray and support
  • hood latch assembly
That is most of it I think..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-16-2008, 12:03 PM   #9
Captkaos
Captkaos's Avatar
This from Gchemist (that I referenced above) It is from a 83 to 89-91
http://www.geocities.com/abetterchem...rillchnge.html
Chris Lucas
1973 Chevy C-10
Captkaos Customs
