Old 10-16-2008, 02:49 PM   #1
larry may
Smile Lower A arms
Would the 1968 lower A arms interchange to include lower ball joints with a 1972 spindel set up? both are 1/2 ton units. Attempt is to convert from drum to disc brakes. Any other parts for the front end need swaped out to make this work correctly and to be safe........... Thanks Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 10-16-2008, 03:10 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Lower A arms
You can use the 68 arms, just swap to 72 ball joints. Also you may need to modify the steering stops to get your full turning radius(not a big issue). Best of luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
