Bucket, console/bench seat F/S
Used bench bucket seat combo. The seat upholstry is in good shape, needs shampoo. The brackets are good and the to mount but the adjuster rod was bent and did not work when I took it out. This could be an easy fix. The only reason I am not using I had found a newer set with the integrated seatbelts.
$75 pick up only 17022
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
These look like what my son was looking for. Put me first in line until I can check with him later today? Where in central Pa. are you located?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Re: Bucket, console/bench seat F/S
Sounds good, near Hershey, Pa.
How wide is the seat? He said his is something like 61-62" side to side. If they're close, he said he wants them. If so, when would you need them picked up? Said he's not sure if he has to work this week-end.
Dan
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() Last edited by OhioDan; 10-15-2008 at 06:04 PM. |
The cushion part of the seat is 60.5" and the mounts were bolted to the factory holes in my 67'. If you are interested you get them when it suits you guys. As long as it is not a year or so, just kidding! Thanks, Jon
![]() Join Date: Mar 2007
If something happens to ohiodan I will take them. Can pick up today. Thanks, Rich
I will let you know if the it falls thru. Thanks, Jon
Jon, will a money order be okay? (postal) PM me your info, and he'll pick up the money order tomorrow. Then we can try and figure out when to come and get them. Ok? LMK.
Thanx, Dan
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() Last edited by OhioDan; 10-16-2008 at 07:34 PM. |
A new C10 Addict!
Why couldn't you be closer those would have been sold already. Good luck with the sale
That is a nice seat, what is it out of I,d like to find one
I honestly don't know? My guess would be an older van or some type of after market seat for a van or suburban, cause it bolted to the factory holes.
Sorry
Jon, PM sent.
