Is the clutch adjustable.....
On a 86 one ton hydraulic clutch. My Dad bought a wrecker, The guy he got it from put in a new clutch and the works. I got in it the other day to move it, and you just barely let the pedal off the floor and it's grabbing. I like my clutch's to have more of free travel before they start to engage. So if you guys can help me out , I'd appreciate it.
If you need more info, Tell me and I'll try to get it for ya's.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Re: Is the clutch adjustable.....
TTT, if anybody can give me any idea. Id appreciate it
Georgia Boy
Sounds like it might need to be bled.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
#4 | |
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) Last edited by gafiredog; 10-12-2008 at 04:58 PM. |
Just here to tinker
![]() Join Date: Jun 2008
There should be an all thread stud going from the slave cylinder to the shift fork. There are two nuts on there, and the one closest to the S/C should be welded. The other nut is at the S/F end and is adjustable. Probably two 9/16 wrenches and a little patience...
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Ok, thanks for the tips, I'll give a look, to see what I can do.
For what its worth (not so much if you know the stores), Autozone.com has repair info. Sort of like online manuals and it says there's no adjustment.
I went out this evening to look at the S/C rod. there's no adjustment there. I did find out the the S/C was considerably loose. So I tightened it back up, but was unable to see if that fixed my problem, because the battery was dead. I have the battery on charge, so I'll check to see if it's any better tomorrow.
#9 | |
Just here to tinker
Well it still grabs alot soonerthan I would like, but it is better than it was. Before you could barely lift there was no time to feather the gas to get going. Now there is a little room to work with but very little.
Just here to tinker
I guess the only other option is to bleed it then...
