Old 10-15-2008, 08:50 PM   #1
shortchev
shortchev's Avatar
Blazer Gas Tank Fill Suggestions
I have searched But I dont know what to do about the fill Pipe for the blazer tank .I have seen trucks with a fill door moved to the bed floor . Anyone have any pics or suggestions ? What did you do if you installed a Blazer tank in a pickup , For the fill pipe ? Thanks Pete
1970 Gmc6500
1951 chevy gasser
1986 crew cab dually
1956 Gmc extended soon to be ?
shortchev is offline   Reply With Quote
Old 10-17-2008, 02:31 PM   #2
budgetstperformance
budgetstperformance's Avatar
Re: Blazer Gas Tank Fill Suggestions
i have not done this but i plan to graft the fill door behind the right rear fender and space it so it looks in proportion like factory. i tryed cutting the filler door out of my saburban donor but this is not going to work because there is alot of thick steal reinforcment attatched to the filler door surround. so next time i go to the junk yard im taking the cordless reciprcating saw. and ill cut out a big enough panel from a truck bed to make it easy to graft in.
budgetstperformance is offline   Reply With Quote
Old 10-18-2008, 08:20 PM   #3
OJOE
Crew Cut
OJOE's Avatar
on my crew cab build i just cut my door out and moved it to the rear of the bed same height from the body line as it was in the front. good luck joe
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
