Old 09-24-2008, 10:44 PM   #1
texastrendz
hydraulic hose for airline
has anyone used hydrauli hose for airlines before. i know it is pricey but you would never have to touch it again. just wondering if anyone has run into problems using it. i think jic fiittings would be the way to go. just tired of copper leaking all the time at the push locks. thanks again.
texastrendz is offline   Reply With Quote
Old 09-24-2008, 11:14 PM   #2
Shane
Shane's Avatar
Re: hydraulic hose for airline
push lock fittings aren't designed for copper ... that may be why you're having problems with the leaks
Shane is offline   Reply With Quote
Old 09-24-2008, 11:17 PM   #3
FnLow69
FnLow69's Avatar
you need compression fittings for copper lines... as for the hydraulic hose it would work but the size is bigger than airline or copper tubing and might make routing harder....
FnLow69 is offline   Reply With Quote
Old 10-08-2008, 11:01 PM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Originally Posted by FnLow69 View Post
...but the size is bigger than airline or copper tubing and might make routing harder....
I used air brake hoses(like for a semi) for leaders on my front bags. A 1/2"ID hose takes up a lot fo space. I couldn't imagine trying to find a place to route it through the whole system.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 10-12-2008, 06:17 PM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I'm running 3/8" hydraulic hose for my system and I love it, no leaks at all!. The hose I'm using routed fine except at the top of the front bags, but that was my fault (welded upper plates in instead of bolting). Anyways, it's not that hard to route and it gives me comfort knowing that the hose can take a little heat (not a ton but more than plastic) if my exhaust is close to it (about 2 inches at the nearest point).
I also used 3/8" viair leader hoses to connect my air tank to the valves as it has a built in check valve and are braided stainless. I'll toss us some pics in a little while (I don't always have internet in the barracks).
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 10-21-2008, 12:11 AM   #6
ENHANCED AIR RIDE
Yes Hydro hose is just fine if u wanna spend the $. Done it on multiple cars. Also used Braided SS line throughout on a few builds, very pricey same result. Yes PTC not really meant for copper, although if done properly it will work.
ENHANCED AIR RIDE is offline   Reply With Quote
