Old 10-03-2008, 06:23 PM   #26
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Re: A/C Retrofit
Thanks guys so I need to get a Evac pump from auto zone and then the retrofit kit?
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 10-03-2008, 06:26 PM   #27
70rs/ss
70rs/ss's Avatar
Re: A/C Retrofit
The retro kit really is just two valves to replace the R12 fittings with 134A fittings and some 134A, so yeah replace any parts then seal it up and pull a vacuum on the system, then fill with 134A.
70rs/ss is offline   Reply With Quote
Old 10-03-2008, 08:08 PM   #28
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: A/C Retrofit
Are you going to charge the system yourself? Do you have a manifold and gauges? Does your system have a charge in it now?
Without the gauges, first check and see if the system is charged. Remove the cap from the low pressure fill valve and push in the stem, it's just like a tire. If you hear any gas coming out, you cannot legally work on it. You need to go to your serviceman and have the R-12 removed. Per the law, you can't release freon into the atmosphere, it must be recovered by a licensed technician.
After the charge is gone, you can replace the dryer and the valve. You can also remove the Schrader valves from the fittings and put on the R-134a adapters.
Recommended practice is to then pull a vacuum for a leak check. If it holds the vacuum, then the charge of R-134a and oil can be added.You need a set of gauges to check the vacuum and charge the system. If you don't have the right tools, let your serviceman do that part.
As for cleaning out all of the oil, you don't have to. The older oil is heavier and lays on the bottom and doesn't hurt anything. R-12 and R-134a can also be mixed, I know of some farmers who started doing it in tractors over 10 years ago.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-04-2008, 02:22 PM   #29
semperfidoordie
Re: A/C Retrofit
so I found a shop that will evac my r12 for free and I can charge it myself... I'm freakin excited here soon shell be just how I want her
Tony
Old 10-21-2008, 03:57 PM   #30
moon
moon's Avatar
Re: A/C Retrofit
Any update on your progress?
moon is offline   Reply With Quote
Old 10-21-2008, 04:13 PM   #31
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: A/C Retrofit
want to read this later.... no time, got to actually do some work here. HAHAHAHA
LOW DOUGH is offline   Reply With Quote
