Junior Member
Anyone ever use air ride valve block?
Re: Anyone ever use air ride valve block?
Looks like a copy of airridetech's block. Never seen how well any of them work, but I'm still happy runnin my oldschool manual valves...
what's the cylinder for?
Built 4 Speed
as usual no help other than my 2 cents.
Easy to install Show quality look Anodized aluminum body 1/8" NPT ports seems small Zinc plated mounting bracket Kip solenoid valves Stainless steel solenoid body Buna seals Built in desiccate air dryer your cylinder Easy to follow installation instructions Made in the USA im sure it works but as with everything you dont see in Truckin's thousands of pages of endorsments you just have to try it.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
i know someone who got one of these but, he is still building his frame
![]() ![]() I'm thinking about running one also. http://cgi.ebay.com/ebaymotors/ws/eB...m=380068788443
![]() ![]() Last edited by joe231; 10-06-2008 at 10:31 PM. |
The gold one is from Arnott, I sell them. Very nice piece, but very slow. The cylinder is a desicant drier. These guys build OEM style stuff, speed is not there concern. Very nice and knowledgable people. Built a badass digital setup, but again very slow. the red one I wouldn't put on anything personally. Asco or Accuair is all we do here, NO PROBLEMS
the bottom picture is of a spool valve. Intended for high volume industrial use in an extremely clean atmosphere and climate controlled enviroment. I wouldnt run them.. if you do I would keep an O ring rebuild kit on hand with tools
