Old 09-20-2001, 04:20 PM   #1
Tuff Truck 41
Post What motors are compatible??
I have a 1973 chevy c-10 2wd pickup, I locked the motor up in it, and I need to know what motors will, bolt up, I know that chevy motors are very compatible, but I have know clue which ones will fit.
Weld Shop
Josh Clayton
Tuff Truck 41 is offline   Reply With Quote
Old 09-20-2001, 06:48 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Post
Any Chevy V8 will fit, Big Block or Small block, from inception to the 2002 models.
An inline6 will also fit.
Chris Lucas
1973 Chevy C-10
1975 Chevy Silverado
Captkaos Customs
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-22-2001, 08:42 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
What do you have in it right now? For 100% bolt in, you'll wanna stay with a simmilar motor as whats in it now. If you have a small block, you'll want a small block. If you have a big block, you'll be broke, if you have an inline six, you'll be searching for a while.
Old 09-27-2001, 11:04 PM   #4
69step
Post
will 350 out of 72 work in 86?
69 Stepside 350 373 rear, power disc.
One day at a time
69step is offline   Reply With Quote
Old 09-28-2001, 12:18 AM   #5
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Post
yes a 72 350 will fit any year will fit
71 Custom/10 lb fleet .040 over 350/th350 good ol 1 wheel peel 3.73 12 bolt 275/60/15 front 31x10.50 rear on GMC Safari wheels
#3 Dale Earnhardt will live forever in our hearts and memories
"THE WORLD'S GREATEST RACE CAR DRIVER EVER"
http://burlinator.freeservers.com/index.html
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 10-06-2001, 10:43 PM   #6
Longhorn Man
Post
You'll have a bunch of wires you won't use as a '86 is computer controlled and a '72 isn't. And if emissions is a problem where you are, that will come into play at your next inspection, but yes, it will go in and work.
Old 10-13-2001, 12:30 AM   #7
Fast68Chevy
Fast68Chevy's Avatar
Post
Yeap, alot of the 81-up trucks and some SW6 HO 305 Firebirds, etc used the EST system, had electonically advanced distributor, knock sensor, etc.
You can run the 72 carb and dizzy on the engine when it goes in the 86, you dont have to use the plugs for the 86 carb or the extra plug for the '86 dizzy, engine wil still run, starting circuit is same.
And use the 86 alternator, it will swap on, as will all of the accesory brackets and pulleys.
Does the 72 engine stil have the original passenger side alternator set up(if is actually a 72 truck engine) ?
Make sure both engines have the 8" diameter torsional dampner(balancer), if not then swap the '86 balancer onto the '72 engine.
Even so, the 86 may not even have the EST sytem in it.
good luck
Fast68Chevy is offline   Reply With Quote
Old 10-15-2001, 02:25 PM   #8
Captkaos
Captkaos's Avatar
Post
An '86 only has a ECS (Electronic Spark Control) and you should ditch it anyway. '87 was the first year for computer control.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Chris Lucas
1973 Chevy C-10
Captkaos Customs
