Old 10-22-2008, 11:55 PM   #1
Swifty
Swifty's Avatar
home made S10 body mounts?
Who has made thier own S10 body mounts? I have NO welding skills so i'd have to take the plans to a welder/machinist to get them done. I heard getting a set made is a lot cheaper than the kit. I'm curious who has made thier own or had some made and used them.
Swifty is offline   Reply With Quote
Old 10-23-2008, 07:19 PM   #2
nova bill
Re: home made S10 body mounts?
i did mine using jeffs plans but used square tubing. if you cant weld you could just drill and bolt through. i believe the thread is "not another s10 swap".
nova bill is offline   Reply With Quote
Old 10-23-2008, 07:31 PM   #3
gr8one
this worked out pretty good, or you can cut tubing 4x4 tubing.just use themeasurments off the pic
gr8one is offline   Reply With Quote
Old 10-23-2008, 09:10 PM   #4
nova bill
you may want to lower the mounts even the designer lowered them after looking at how high it sat. i dropped mine using a 2x4 plus the rubber mounts. just decide where you want the body heighth.
Old 10-23-2008, 09:59 PM   #5
gr8one
i also lowered mine 2" above the frame and used the s10 rubber
Old 10-23-2008, 11:37 PM   #6
jeffs51chevy
jeffs51chevy's Avatar
Swifty, the mounts are easily made using tubing or bent flat stock. If you need pics of the mounts themselves or have questions, just let me know. The question you need to ask is, "how much modification do you want to do?" The higher you go, the less changes you need to make. If you go six inches or more, everything rides on "top" of the frame and you don't have to cut much. I was there once and it worked ok. In my opinion, for the amount of work this swap takes, I have decided to go lower. Currently my front mounts are 3 1/2 inches plus the s10 cab bushing. The rear mounts are 4 plus the bushings. If you haven't checked out my thread, you can see it at http://67-72chevytrucks.com/vboard/s...d.php?t=294539. If you have any questions, I will try to help out as much as I can.
Thanks,
Jeff
jeffs51chevy is offline   Reply With Quote
Old 10-24-2008, 01:57 AM   #7
Swifty
Swifty's Avatar
thanks for the replys! if you don't mind can you post pics of the mounts installed w/out the cab? I like the look of 2" above the frame but what cutten/mods is needed?
I originally was going to use the s10 swap kit that can be purchased but i kinda need to budget this build now, but i think we all know how that goes.
Thanks again guys! this is my first frame off build and i'm pretty new at all of this so i'm sure i'll have a TON of questions as the build progresses.
Old 10-24-2008, 04:57 AM   #8
55dude
55dude's Avatar
i have a 58' that somebody put on a later chevy pickup frame (67'-70) and they just used round tubing. the mounts are easy as you just need some wood to get your spacing and transfer to metal.
55dude is offline   Reply With Quote
Old 10-24-2008, 11:30 AM   #9
51chevytruck
Be careful How much you lower the cab, it will affect other items such as the clearance between your trans tunnel and cab. This area would have to be modified/cut. I have found the optimum clearance between the distributer and stock firewall to be about an inch. In this position I have about a 1/2 inch clearance between my trans and cab. I fabricated 3/8's plates and bolted those to the frame, then fabricated mounts that placed the engine mount bolts about an inch above the plates. (Hope this doesn't sound too confusing)
The reason I mention this is because there is very little room to play in mounting the eng for and aft especially if you want to run a mechanical fan.
I don't know how high my cab is sitting in relation to my frame I would have to measure but 10.25 sounds about right.
51chevytruck is offline   Reply With Quote
Old 10-24-2008, 05:59 PM   #10
neolowrider
i just used 2x3 tube. bolted it to the frame. pics in my post.. (s10 swap...yea another one)
neolowrider is offline   Reply With Quote
Old 10-25-2008, 07:35 AM   #11
iokua80
iokua80's Avatar
I used the stock rear s10 mounts for the front AD mounts. The rear still uses the stock AD shackle
iokua80 is offline   Reply With Quote
Old 12-06-2008, 11:33 PM   #12
jeffs51chevy
I know this thread is a little old, but I had my cab off. Here are some pics:
Front
Rear
Hope it helps
Old 12-07-2008, 04:13 AM   #13
Swifty
Swifty's Avatar
thank you for the follow up. the pics really do help!
Old 03-14-2016, 03:25 PM   #14
lsjrl07
lsjrl07's Avatar
Has anyone used these mounts for an AD Suburban. I am wondering if they're the same? I am compiling parts for my tear-down and rebuild.
lsjrl07 is offline   Reply With Quote
Old 03-14-2016, 03:33 PM   #15
67 chevelle
67 chevelle's Avatar
thread is 8 years old , check the sticky up top on s10 swap , by skymags
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-23-2016, 08:14 PM   #16
BigFrz
Any pics on how you did the mounts for the bed and back rear. And how you did the front end mount
Juan Frias
BigFrz is offline   Reply With Quote
Old 03-23-2016, 09:28 PM   #17
chopit
chopit's Avatar
chopit is offline   Reply With Quote
