10-22-2008, 07:30 PM | #1 |
Zn' the frame
Why? What does this do? Does it need to be done to get the truck to lay frame? Anyone here do a step by step with pics thread? i think i have an idea. just want to se some shots
10-22-2008, 07:56 PM | #2 |
soon to be bagged64sub
Re: Zn' the frame
Yes it has to be done to lay frame. The front supension and crossmember hang below the frame. The Z raises it so the frame is the lowest point. Look through the suspension section to find pics. Here are a few of the Z i had on my 69. This one wasn't finished. I also put a plate on the inside of the frame after this pic was taken. The second shows how the steering needs to be modified.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
10-22-2008, 09:34 PM | #3 |
Re: Zn' the frame
Yep, 69 had it right. To lay it'll need to be atleast 2 and at max 4 inches. But you can throw down and go big on a dropmember to get it out of the way, but there aren't any other alternatives.
10-24-2008, 07:45 PM | #4 |
Re: Zn' the frame
What about Zn the rear. Is there a max? Also if i Z the rear, then i should not need to c-notch it or build new back half right?
10-24-2008, 09:17 PM | #5 |
Re: Zn' the frame
Back is a different story you will have to raise the bed floor or be gone with it and its simpler to put a big notch in. I look at it this way if your going to z the rear just cut it off and back half the truck its the same amount of work. Do a search in the suspension forum you'll find endless amount of info.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 10-24-2008 at 09:18 PM. |
10-24-2008, 09:29 PM | #6 | |
Re: Zn' the frame
Dont forget you have to rebuild/modify the trailing arm crossmember! Last edited by PrerunnerRob; 10-24-2008 at 09:37 PM. Reason: adding pictures |
10-24-2008, 09:52 PM | #7 |
Re: Zn' the frame
It all depends on the builders goal. Z'n the factory rails can & does work well if you like the bags in the stock coil location. If it's planned well, it simplifies several things.
If you're going to move the bags though, you prob would be better off w/a different suspension or back-half it.
10-24-2008, 09:55 PM | #8 |
Re: Zn' the frame
hey Rob, you dropped a smoke
looks nice
CHEVY ONLY |
