Old 10-24-2008, 03:40 PM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Pitman Arm Removal
The stupid puller isnt working. Ive beat the **** out of it with a sledge. Is there something im doing wrong? Is there something holding it on that needs to be taken out first?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 10-24-2008, 03:42 PM   #2
1970heavychevy
busted knuckles
1970heavychevy's Avatar
Re: Pitman Arm Removal
You sound as frustrated as me. I would push mine off a cliff if I could get it there.
1970heavychevy is offline   Reply With Quote
Old 10-24-2008, 03:48 PM   #3
LuckyHenriksen
Haha ya i love these old heaps but when nothing you try works, its easy to get angry
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 10-24-2008, 03:51 PM   #4
1970heavychevy
busted knuckles
Mine is one step forward and two steps back. I need a second one to beat the crap out of when something goes wrong with the main one.
Old 10-24-2008, 03:56 PM   #5
LuckyHenriksen
Ya perfect excuse to get more
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 10-24-2008, 04:06 PM   #6
leddzepp
Moderator
leddzepp's Avatar
the puller should work with no problem...did you lube the crap out of the arm?
Old 10-24-2008, 04:17 PM   #7
LuckyHenriksen
Ive had it soaking in WD40 for the last day/night. Do I need something more powerful than WD?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 10-24-2008, 05:12 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
WD-40 is not a penetrating oil.Get some Kroil,PB Blaster,or liquid wrench.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-24-2008, 05:25 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Old 10-24-2008, 06:00 PM   #10
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Kroil from the manufacturer:
Kanolabs.com
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 10-24-2008, 06:09 PM   #11
cdowns
cdowns's Avatar
install puller tighten up then wack the puller stud hard with heavy hammer then tighten again wack wth hammer //the tension on the arms combined with the shock of the blows with the hammer just a little movement each time till it breaks loose
Old 10-24-2008, 06:38 PM   #12
Billhilly
Billhilly's Avatar
You gotta try this stuff sometime guys. I is a welder/engineer and am using it more and more. Great stuff to have on the shelf/ in the tool box. Might be just what you need, oh and what cdowns said.
http://www.henkel.com/cps/rde/xchg/S...8_USE_HTML.htm
Bill.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 10-25-2008, 12:41 AM   #13
LuckyHenriksen
Alright thanks guys. After repeated attempts the BFH won
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 10-25-2008, 08:06 AM   #14
68C15
blood type; Retumbo
68C15's Avatar
they ALWAYS come off easy for me.
I use a cuttoff wheel to make a slit in the arm almost to the splines being carefull to not hit the box. then I use a puller and it slides off real easy. no pounding or other form of abuse involved.
68C15 is offline   Reply With Quote
Old 10-25-2008, 08:42 AM   #15
ChevyC102007
ChevyC102007's Avatar
I guess I got lucky when I changed the pitman on my '71, hooked the three jaw up and turned it with a breaker until the pitman popped lose. Brute force won that day (probably didnt hurt that the dang thing was already tryng to work its way off). My major headache was the dang idler arm but alittle "liquid red wrench" aka blow torch helped with that.
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 10-25-2008, 09:00 AM   #16
msgross
msgross's Avatar
umm, the nut!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-25-2008, 09:01 AM   #17
Hawker7
I have found that by using Kroil and if practical, heat, you can get almost anything apart.
Hawker7 is offline   Reply With Quote
Old 10-25-2008, 11:13 AM   #18
LuckyHenriksen
Originally Posted by msgross View Post
umm, the nut!
Ya I found that out. Definitely made it easier
I had to use my torch on the idler arm too. Filled up the garage with smoke, it was awesome.
I feel bad laying so much abuse on something directly tied to the steering box. Oh well you gotta do what you gotta do
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
