10-23-2008, 09:31 PM | #1 |
steering column compatablity
I have a chance to get a steering column out of a 93. Does anyone know if it will bolt up in my 79 without any mods. I can get the ignition switch parts too if those would need to be changed.
'79' shortbed |
10-23-2008, 09:36 PM | #2 |
Robert Olson Transport
Re: steering column compatablity
probably not.. the wipers and all arent on the stalks on a 79.. plus a newer model has more bells and whistles usually like cruise.. im betting the turn signal wiring wont line up right either or the linkage... im not sure that the column will bolt directly in either or even to the lower shaft
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-24-2008, 12:26 AM | #3 |
|I took a 86' column and put it into a 74' but i had to change out the wiring harness and alot of switches
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
10-24-2008, 08:37 AM | #4 |
Thats kinda what I was thinking but not sure. Thank You all for the responses.
'79' shortbed |
10-24-2008, 09:54 AM | #5 |
www.73-87chevytrucks.com
I think the column mount is different (I have a 93 column to go in one of my trucks - floor shift column) It is do able though, the actual column on these were the same from 73-94 or whenever they started putting airbags in. Wiring will be necessary for all the switches to work.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-25-2008, 04:18 PM | #6 |
thanks Cptn, I'm wanting to put in a b&m automatic shifter and found a 93 floorshifter column. All i'd need is ignition horn and turnsignals.
'79' shortbed |
