10-22-2008, 11:46 AM | #1 |
H2 wheels
No doubt this question has been posted before....I couldn't locate anything with the search. Will 2003 up Hummer H2 18" wheels work on my 1970 3/4 Ton 4x4? I found a chrome set with decent tires for $250. Just want to make sure the offset will work and no rubbing will occur. Will they need special lugs?
1970 C20 350 4-Speed no options but only 56K original miles.....Now a K20 mutt with a SB400! 2002 Impala LS (wife's car) |
10-22-2008, 02:39 PM | #2 |
Re: H2 wheels
They should work - 8 lugs are all 8x6.5 for Chevy/Hummer - Fords changed patterns to metric around 1999 (I think).
Different Lugs - yes - you will need to get 32 of the double threaded lug nuts (if you intend to run center caps) - rear dually caps from mid 80s-early 90s will work. Board member 72 Freak has a set on his Suburban and they look great - if you have ? - you may want to track him down as well. Not sure of the thread size on 70s - my 72 uses 9/16ths thread - not sure if that is standard between years or not though. I would hate to steer you wrong. Double check what you have. They are cheaper and easier to find here (no relation or vested interest) - just who I used - http://www.ezaccessory.com/GM_9_16_E..._p/98-0009.htm I found one of their auctions on ebay - and bought them - $32 shipped (if I recall correctly). Here is another post to assist you (or ask questions to the owners). http://67-72chevytrucks.com/vboard/s...d.php?t=132709 |
10-22-2008, 03:44 PM | #3 |
Re: H2 wheels
I have a set of the 17"'s and they bolt right up and the offset isn't too bad either.
10-23-2008, 04:06 PM | #4 |
Re: H2 wheels
Hey, thanks a bunch for your input and the link. I would love to see how these wheels look on our trucks before I get carried away. Anyone got pics of their trucks with Hummer H2 wheels?
10-23-2008, 06:45 PM | #5 |
Re: H2 wheels
I have the wheels and the truck, just no tires!!
10-23-2008, 09:50 PM | #6 |
Re: H2 wheels
They're 17 inch. I have them on my 72 4x4 with the stock h2 tires. They fit great but are close enough to barely rub the drag link end where it attaches to the pitman arm on full lock right turns. I had to adjust the steering stops on that side out a little. I think they look good, but I run them without a center cap. Sorry, no pictures on this computer. A search may find some.
10-24-2008, 03:50 PM | #7 |
72 C30 Trailer Queen
Re: H2 wheels
Board member Brewski's truck.
This truck had a 4 inch lift.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
10-25-2008, 06:17 AM | #8 |
Re: H2 wheels
What about a '67 4X2 C20, stock height. I have a set of H2s collecting dust. Anyone have any pointers on tire size that would work in my situation?
Maybe I should pose this question in a new thread.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
10-25-2008, 08:15 AM | #9 |
Re: H2 wheels
Here's a set on some one tons.
10-25-2008, 11:32 AM | #10 |
HERE.......Somewhere
Re: H2 wheels
are the H2 rims 6 lugs???
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
10-25-2008, 06:22 PM | #11 |
SWB 4x4 Collector
Re: H2 wheels
The H2 rims are 8 lug.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
