tryin to get laid
Re: Is this too much money?
Definitely use the one piece Felpro gasket... It is reusable and will save you money in the long run. Not to mention it is probably less likely to leak.
It'd be alot cooler if you did
x2
Yes as mentioned in above posts make sure it isnt coming from an intake,valve cover or oil sending unit.Check that first could be a combo of all
i took a look at it and i would have to remove the exhaust as i could not get the oil pan out because they hit. Probably the starter, oil pan, main bearing cap, and maybe a few other things. Im going to double check and see if it is oil running down the block either from the intake or the oil temp sending unit. thanks for the help guys. if its the 2 pc seal, i think i will just take it in to get it done as fast as i can
#5 | |
Chevys Kick A$$
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Last edited by Hoods69BadBowTie; 10-27-2008 at 12:32 AM. |
