A new C10 Addict!
Power brakes but not so powerfull
I have a 67' C10 with power brakes and well up until tonight I thought I had manual brakes. The brake pedal only moves about 1/2 a inch and when pressed I have to put quite a bit of effort in pressing the pedal to stop the truck. The truck feels like it wants to jump some times when sitting at a light. What should I look for to fix my issue? Thanks LeDevil
Re: Power brakes but not so powerfull
2 things in my opinion, I guess one question and one thought. Do you have 4 wheel drums? I would say it could be a vacum leak?
Its Deja Vu time again
1/2 inch of slop moment in the brake pedal before the brakes activate or you only have a total of 1/2 of movement in the brake pedal total?
A new C10 Addict!
chrismoore701: Yes it has 4 wheel drums, Where would you think the vacuum leak would be? How would I check for that?
kizer: I have a total of 1/2 inch of movement there is no slop. Thanks for the reply's guys Last edited by LeDevil; 10-27-2008 at 01:38 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
swap to disc brakes up front.
![]() Join Date: Feb 2008
If I remember correctly, you should be able to put your foot on the brake pedal with the engine off, Start the engine and the pedal should go down some. If it doesn't then your power brake unit is bad. You can check the hose to the unit for vacuum leaks.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
My dad has a corvette with 4 wheel drum, not power, and you better pray if you need to stop fast. As for checking for vacume leaks, what I do is take a can of carb cleaner and spray near the vacume hose, if there is a leak, it will suck the cleaner into the engine and the engine will rev higher. check the hose and connections. good luck
I'm guessing automatic? Sounds like the idle might be a bit high compounding the problem.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
