Old 10-25-2008, 08:42 PM   #1
Hart_Rod
Hart_Rod's Avatar
402 BBC and stuff F/S (Albuquerque, NM)
*** Possible trades, buddy buckets...... ***
I don't know the mileage, but it was supposed to have run before it was pulled. It comes with Holley Aluminum valve covers, Holley factory steel intake, new fuel pump, new spark plugs, exhaust manifolds, Holley 750 carb (looks nearly new) and a turbo 350 tranny (probably needs rebuilt). $550 o.b.o.
Block: 3999290, T02090 TBH
Heads: 3999241.
Complete inner and outer heatcore, fan, and controls $80 shipped.
Hart_Rod is offline   Reply With Quote
Old 10-26-2008, 09:29 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 402 BBC and stuff F/S (Albuquerque, NM)
Forgot to mention I've got a turbo 350 I will throw in with the deal.
Old 10-26-2008, 11:37 PM   #3
DieselEater
DieselEater's Avatar
you got casting numbers on heads and block?
A...........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 10-27-2008, 08:29 AM   #4
Hart_Rod
Hart_Rod's Avatar
A...........
I believe engine block is 3999290, but I'll double check and look at the heads. The numbers on the front of the block are: T02090 TBH
R/
Old 10-27-2008, 10:38 AM   #5
Luvlegs
Luvlegs's Avatar
Is the carb a 4779C?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-27-2008, 12:52 PM   #6
Hart_Rod
Hart_Rod's Avatar
I believe its a 3310, dual line feed, 750 cfm.
Old 10-27-2008, 01:22 PM   #7
70rs/ss
70rs/ss's Avatar
Rob, $550 for the whole package with trans? If so I may be interested, if diesel decides not to?
BTW: Both numbers point to a 72 402 2-bolt FYI
TBH 70 402 Truck 310 L-47 Manual 4-Brl All Models
3999290 402 72 2-bolt
70rs/ss is offline   Reply With Quote
Old 10-27-2008, 01:46 PM   #8
Hart_Rod
Hart_Rod's Avatar
THB 72 402 Truck 210 L-47 TH-400 4-Brl
$550 for all and I messed the letters up again, its TBH not THB......
Old 10-27-2008, 01:56 PM   #9
70rs/ss
70rs/ss's Avatar
I changed it, looks like this one is a bit more peppy that the other? I need another BBC like I need another hole in my head, but the intake is something I'd like to get and $550 isn't too steep if it'll run. I'll ask but not sure if you need anything? I have too much stuff and a lot of parts? BTW I haven't been back to PHX, but should be in DEC and I can try to get the seat? LMK
Old 10-27-2008, 07:18 PM   #10
Hart_Rod
Hart_Rod's Avatar
Can't guarantee it will run, because I didn't hear it myself. That's just what the PO told me. As far as parts, all I really need is a set of sport bumper brackets for a leaf spring rearend. I'm not sure what's going on with the buddy buckets. Last I heard they went back to Cali due to a death in the family. I'm still trying to figure out what he wants to do...... Let me know.
R/
Old 10-27-2008, 07:43 PM   #11
DieselEater
Not interested in 2-bolt block.......If heads are good casting may be interested in them if will part out.
Thanks for reply,
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 10-27-2008, 08:24 PM   #12
Hart_Rod
Hart_Rod's Avatar
Thanks for reply,
A........
Thanks, but I prefer not to part it.
Old 10-28-2008, 02:44 PM   #13
Hart_Rod
Hart_Rod's Avatar
Looks like your up next 70RS/SS. Let me know.
Old 10-29-2008, 01:40 PM   #14
70rs/ss
70rs/ss's Avatar
Diesel what are the heads worth to you, cause I have Vortecs I'd use, and it would help me out?? I'll PM you and get back with you Rob.
Old 10-29-2008, 08:12 PM   #15
DieselEater
Got your PM.........just depends on the casting.
A..........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 10-29-2008, 09:12 PM   #16
Hart_Rod
Hart_Rod's Avatar
A..........
I know they are the stock heads but I haven't gotten the numbers yet.
Old 11-06-2008, 12:47 PM   #17
Hart_Rod
Hart_Rod's Avatar
Ttt
Old 11-13-2008, 05:46 PM   #18
Hart_Rod
Hart_Rod's Avatar
I pulled the valve covers and the head numbers are 3999241.
Old 12-07-2008, 01:05 PM   #19
Hart_Rod
Hart_Rod's Avatar
Bttt
