Old 10-20-2008, 04:59 PM   #1
Imacarguytoo
3/4 to 1/2 ton Panhard bar
Guys im close to installing the 1/2 ton rear end and removing the 3/4 rearend. Is the 3/4 ton panhard bar the same as the 1/2 ton bar.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 10-20-2008, 06:52 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 3/4 to 1/2 ton Panhard bar
That all depends on what rear you have. If the bar mounts to the diff, you *might* be OK. If yours is currently mounted on the axle tube, it will be too long...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-21-2008, 08:19 AM   #3
Imacarguytoo
It mounts to the diff on both
Old 10-21-2008, 08:48 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Maybe someone here can get you a measurement on a stock one. I think they're around 24"...
-Chris
Old 10-21-2008, 10:01 AM   #5
cdowns
cdowns's Avatar
unless you're going for stoch height you're going to probally need aftermarket adjustable panhard bar
Old 10-21-2008, 10:43 AM   #6
primered_junk
ASE master tech/machinist
primered_junk's Avatar
They are close to the same, been there done that with no issues.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 10-27-2008, 11:54 AM   #7
Imacarguytoo
Ok great Thanks guys.
