Old 10-27-2008, 02:27 PM   #1
olivedrab
Im STUMPED
i have an 87 swb chevy 4x4 with the tbi and computer. recently my msd 6a box along with the ignition module in the distributor go out. So i eliminated the msd box and changed the ignition module in the distributor.
here is the problem:::: the truck runs great, nothing abnormal until it warms up. after it warms up, i put it in drive and it dies. its almost like it just chokes out.
things ive checked: idle air control valve, dampness in the distributor cap, ignition circuit wirring, vaccum leaks around the intake and such. still havent found anything abnormal.
for the temporary fix i just unpluged the temp sending unit that goes to the computer from the top of the intake manifold and it idles a little higher thus resulting in it running normal now.
anybody run into something like this?
thanks in advance for the help
87 chevy-350 tbi-4x4-swb-4" lift-37inch claws
72 gmc- 350 carb- 2wd-lwb, soon to be 4x4?
olivedrab is offline   Reply With Quote
Old 10-27-2008, 03:39 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Im STUMPED
Is it throwing any codes?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-27-2008, 05:24 PM   #3
grinch4om
dang its hot
grinch4om's Avatar
Re: Im STUMPED
when you unplug the ECT, it tells the computer the engine is real cold, thus throws more fuel at the engine,(pulsing the injectors more rapidly and or holding them open longer) if it runs normal when you do this, look for a vacuum leak...bottom of intake? Fords say cold when unplugged (ECT), find out what GM does, if it is opposite, it would lean out a fat mixture, either way, I would check the ECT first with an ohm meter if it is ok, go after the above.
grinch4om is offline   Reply With Quote
Old 10-27-2008, 05:48 PM   #4
suicide 63
Re: Im STUMPED
I had a similar problem on a 89 tbi thought it was ignition problem ,but it was a worn out intank fuel pump.It would run good when cold but after the pump got hot it would not pump enough pressure.Good luck
suicide 63 is offline   Reply With Quote
Old 10-28-2008, 02:17 PM   #5
olivedrab
Re: Im STUMPED
no its not throwing any codes...
Old 10-28-2008, 02:19 PM   #6
olivedrab
Re: Im STUMPED
i bought the $12 sensor that tells the comp. the temp but its still doing the same thing. i also took a can of carb cleaner and sprayed around the intake to see if it would suck anything up and idle faster momentarily while burning the carb cleaner and still found nothing...
Old 10-28-2008, 02:22 PM   #7
olivedrab
Re: Im STUMPED
this is a good idea but i just changed the fuel pump about 3-4 months ago.. so im pretty sure its not that in this case...
Old 10-28-2008, 03:43 PM   #8
rfmaster
rfmaster's Avatar
Re: Im STUMPED
Olivedrab
Take a look at fuel spray pattern at idle. It should be a nice cone of fuel mist hitting the walls of the TB bores, not a large drops dripping from injectors falling straight down onto throttle plates.
Disconnecting CTS results in ECM seeing high input CTS voltage (about 5 volt) which corresponds to a very low coolant temperature (-40F). Furthermore, with CTS disconnected, after about 2 minutes of running ECM will set Code 15 (open CTS circuit). Based on your description it is worth while to check fuel pressure. It is not too uncommon for a 'new' fuel pumps to fail, or output hose between fuel pump and feed through to burst.
Also check fuel filter.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 10-28-2008, 05:14 PM   #9
suicide 63
Re: Im STUMPED
Originally Posted by rfmaster View Post
Olivedrab
//RF
Like he said if it is a parts store fuel pump even though it is pumping it may not be putting out the psi you need.We replaced the plugs ,wires ,then went to the module and then replaced the whole dizzy and still had the same problem.
Old 10-29-2008, 02:41 PM   #10
olivedrab
Re: Im STUMPED
alright i guess i have to drop the tank then. the only thing that puzzles me is why it would happen the same time my ignition module went out on me driving down the road.... somethings fishy but ill find it. ive got to get this thing back on the road so i can start on my 72 2wd to 4x4 conversion.
thanks again rfmaster and suicide 63
Old 10-30-2008, 04:00 AM   #11
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Im STUMPED
Your stumped?
What happened?
Accident?
Cancer?
Birth Defect?....... Oh
uhmmmmmmmmmmm...............
wait a sec.......
Ok never mind. My colleague just explained it to me....
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-30-2008, 05:50 AM   #12
grinch4om
dang its hot
grinch4om's Avatar
Re: Im STUMPED
like I said, if you unplugg the ECT(which is confirmed as telling the computer its -40) its lean and the computer fattens it up with the ECT umplugged therefore, fuel pressure, fuel volumn, vacuum leaks, injector spray, all the things that would cause it to be lean but able to be fattenned up by the computer. diagnosing is a fine art and you have to take a step back and think...which is cause and which is effect
Old 11-03-2008, 03:34 PM   #13
olivedrab
Re: Im STUMPED
alright i got another new fuel pump for it yesterday. today im gona drop the tank, stick the new one in and see what happens.
Old 11-04-2008, 03:35 PM   #14
olivedrab
Re: Im STUMPED
ok. i changed the fuel pump yesterday with a new one. same problem.
so far this is what it isnt:
fuel pump
vaccum leak around intake
moisture in distributor
coolant temp sending unit(for comp.)
ignition wiring
still need input please!!
thanks
Old 11-04-2008, 08:15 PM   #15
rfmaster
rfmaster's Avatar
Re: Im STUMPED
Olivedrab
Did you actually measure fuel pressure before and after swapping pumps at the inlet to TB??? If you are able to keep it running with disconnected CTS it indicates fuel starvation.
Things to look for -
Broken fuel regulator spring inside TB - this will keep fuel pressure low and starve injectors! A simple fuel pressure check will show that. TB needs 11 to 14 PSI for happy operation. Anything below 9 PSI will be trouble. TB Rebuild kit will have a new spring and diaphragm. Pop the torx screws of the top of the regulator and take a look inside. Link below shows what it looks like.
http://members.shaw.ca/betterthanyou...to/fpr/fpr.htm
Clogged injector - take a look a the injector spray pattern at idle. Disconnect one injector at a time see if idle stumble is the same of either injector.
//RF
"The Beast"
Old 11-04-2008, 09:51 PM   #16
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Im STUMPED
When you replaced the Ign. module did it come with a small packet of white paste like grease? and if it did! did you use it?
I know alot of people throw it away.
Cuz your suppose to paint that stuff on the under side of the module to isolate it from the heat of the dizzy. if you dont it will cause the Ign. Mod to have a dielectric break down and fail and that may be whats happening to you.
Good luck.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-05-2008, 03:36 PM   #17
olivedrab
Re: Im STUMPED
Good luck.
yea i used the entire packet of the special grease that came with it...
Old 11-05-2008, 03:39 PM   #18
olivedrab
Re: Im STUMPED
Olivedrab
//RF
no i didnt check the fuel pressure before or after. the pump that was in there was still under warranty so i pulled it anyways since it wasnt costing me anything but time and effort, and it also give me the chance to double check everything as far as that goes.
quick question, is there any way to check fuel pressure without an inline fuel pressure gauge? cuz i dont have one of those... but i can get a hold of one.
thanks again for all ure help rfmaster
Old 11-06-2008, 05:12 PM   #19
rfmaster
rfmaster's Avatar
Re: Im STUMPED
Yea, stock TBI system does not lend itself for ease of fuel pressure checking. Depending on which fuel pressure gauge test set you have it may have and TBI specific T adapter section. Even if you do have an adapter it is a PITA since OEM fuel lines are hard to get to and move in order to insert T section (in the back of TB).
Alternatively, you can insert a 3/8" T and appropriate sections of rated fuel hose at the fuel filter. It will not be as accurate, but it will give you a clear indication if you have low fuel pressure.
//RF
"The Beast"
