Pick'n up the pieces!
Header opinions
Hi All, I am close to getting my 350 rebuilt and will be dropping it in my frame soon. I'm ready to buy a set of headers and thought I would get everyone's thoughts on their headers, brand, quality, etc. I'll probably go with coated ones. Also vendors with best prices. Thanks, Danny
Got Big Block?
saw your screen name and can't help but ask, are you a former vaulter? not too many of us around.... oh to answer your question, I've been running a set of Flowtechs ceramic coated for about a year and I really like them.
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 02-21-2003 at 12:20 AM. |
Fabricate till you "puke"
I have hooker comps(painted) on the longhorn,& am happy with them. They are a bit pricey if you are looking for coated headers tho.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
its all about the +6 inches
I can post pics of the super comps on my ride too...I love them.
Yeap, used to bend them old fiberglass poles. That was an old handle I had. Sure wished I could change to something new on the forum. I just wasn't thinking at the time. Did not realize how I would become hooked on these trucks, but I'm in deep now. And lovin' it. Where did you guys buy your headers.
Does Wes or any other vendor on the forum sell them? Thanks, Danny PS Has anyone ever got their handle changed on the forum? If so how? |
I got my hookers through Jegs....crazyL
I would spend the money up front and go with the hooker super comps, coated. Just my 2 cents worth
Sam
72 LWB chevy truck. Pasadena, Texas |
Wiseass secured himself a BAN
Depends on if your truck in auto or manual. I have the clutch linkage that gets in the way of most headers. I had to get some hedders from headman. Hedman at the time was the only ones that had hedders that cleared the linkage.
Ben |
Mine were on the truck when i got it.
I agree though, if you have the cash, you may as well get the best you can, otherwise it'll nip you in the rear when you least expect it. (or least able to spend the $$) |
Used to have a truck
I'm using $79 summit headers on mine with copper flange gaskets and aluminum collector gaskets. 10,000 miles and I havent had to retorque and I havent had any leaks. Coated headers would be nice but I cant see spending another $300 to get a set.
No truck :-( |
14.1 @ 96MPH
You can get coated Dynomax headers for $230-$250 or so at Summit...
I'm still debating long tubes vs Chevelle shorties. My truck is lowered, and I don't want to have the exhaust any lower than where it's at now (which is tucked up against the frame)
Project1970 - LS1 Swap Complete! ![]() |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Formerly yellow72custom
I'm running a set of non-coated Hedman headers on mine. They were pretty cheap ($103 from Summit), and have been on the truck for 2 years and 16k miles. I have had to replace the el-cheapo gaskets i used once, but no other real problems with them. But the passenger side collector kinda points up at the cab. Looks a little weird, but they work just fine.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Thats the Hillbilly way
I'm running Dynomax Cerama-coat headers and love them.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#15 |
Another vote for dynomax jet hot coated from summit. I think I paid like $220 for them.
Hey, I have my old headers if you want them ![]() |
#16 |
Registered Cruiser
Cheap Headers
I bought a set of Flo-Tech headers in '97 from Supershops (before they bellied up) for $69 They've been on the truck for over 5 years, and 90,000 miles. The shop that did my exhaust did a really nice job of suspending it. (2.5" Turbo mufflers with side dumps). There is no weight bearing on the headers themselves, and the exhaust moves pretty freely with the motor torqueing around. I beleive this has a great deal to do with everything lasting as long as it has. Rust is not a big deal here in the middle of the desert either. Eventually of course they will wear out, but I will happily buy another set. Oh yeah, and the clutch linkage clears fine.
I intend to live forever. So far, so good. |
#17 |
Thanks for all the responses. Where else can you get this type of feedback. I hit the Decateur, TX swap meet today and didn't score on a set of headers, but it was a good meet. Guess I'll pull out the catalogs and use everyones advice and see what I can come up with. Thanks again, Danny
#18 |
If the 4x4 headers will clear the 2x crossmember, they should have more ground clearance. I have a set I pulled off my Jimmy. The little flange for the bolt on collector leaked, so they will need to have slip on collectors or be welded to the pipes. They are Heddmans and clear the manual trans linkage. I'll take $40 plus shipping for them. Also, it looks like a set of 68-82 Corvette headers will work well in these trucks and provide tons of ground clearance.
#19 |
Im runnin' thorley tri-y's ceramic coated.They cleared my clutch linkage with no modifcations.The have some thick flages too...helps to not blow as many gaskets.They werent cheap but its well worth it and they look awesome.Keep truckin'!
