Old 10-27-2008, 08:20 PM   #1
C-10volvo
C-10volvo's Avatar
Talking Sway bar info
As this "season" is coming to a close and a prepare the truck for fall and winter sitting on jack stands I want to get a few things done on the front end.
I will be rebuilding the entire front end all the way till the A arm bushings. During that process, I will be putting on Belltech drop spindles with the possibility of a 1" drop coil if its not low enough.
My Question: What swaybars are you all using? (I would like to go to a thicker aftermarket option to match the rear)
Does lowing require any special drop links or bushings for the sway bar? (I know a spindle doesn't change the geometry, but will the spring cause any interference?)
Other than drilling some holes, nothing too radical needs to be done right? (This is a original no front sway bar truck)
Thanks for the info guys!
Ken Morgan
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 10-27-2008, 08:37 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Sway bar info
You can run aftermarket, or cheap out like me and get a factory 3/4 ton bar. I bought a used bar and went with new hardware and bushing for about half the price of an aftermarket bar.
The factory "stands" on the frame are riveted on. You don't really need them since you are lowering the truck. You have two options there. You can use the ECE lowered stands (link) or you can bolt the clamps directly to the frame.
Since you are going with a mild drop, I would think the lowered stands would give you the best alignment and possibly prevent binding. That's just opinion though as there are several that have mounted them to frame with no stands and haven't had a problem.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-28-2008, 04:12 AM   #3
dooce
Re: Sway bar info
ECE only shows an application up to '72. Will they still fit on the 73-87 frames?
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 10-28-2008, 05:01 AM   #4
S10Fan
Old Heap Driver
Re: Sway bar info
I don't have a picture to post but I bolted my clamps directly to the frame. No issues at all. Drop spindles and cut 1 coil.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 10-28-2008, 11:08 AM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Sway bar info
Here's mine. It's a Bell Tech bar from Summit. Very thick, and good quality, comes with all the mounting hardware.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-29-2008, 04:00 PM   #6
C-10volvo
C-10volvo's Avatar
Re: Sway bar info
Thanks for the info guys.
I'll see if I can save some cash and try out the junkyard approach first.
Are 3/4 and 1 ton bars are the same?
Thanks again,
Ken Morgan
Old 10-29-2008, 09:18 PM   #7
LEEVON
Moderator
LEEVON's Avatar
Re: Sway bar info
I believe the 3/4 and 1 ton are the same. Save your cash and get one from a junkyard. Bushings are cheap too. Even the 1/2 ton bars are a major improvement. Like N2TRUX said, you can get ECE stands or connect to the frame. Another option is to use the factory stands and flip the bar/straps to the inside.
If you get a junkyard bar, the stands are riveted to the frame. I paid them $20 extra and they just torched out sections of the frame too.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-30-2008, 09:12 AM   #8
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Sway bar info
If you go with just spindles, there is no need for the dropped stands. The control arms will be in the same location with regard to the frame as they were before. I doubt 1" springs would make much of a difference either.
I bought my stands from the dealer. I think theywere about $9 apiece when I bought them 3 or 4 years ago.
Slonaker
EDIT: My truck didn't have a swaybar either. There were no holes to drill. The holes for the stands and for the swaybar ends were already there. It couldn't be easier.
I have 2.5" drop spindles, new stock springs, and stock stands for the swaybar. No problems. No binding, and they have never hit any curbs or anything.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-30-2008, 11:15 AM   #9
smashingchuck
Re: Sway bar info
When my truck was static dropped (cut coils only, stock spindles) it still had the stock stands on it with about 5-6" of drop. Never had a problem with that either.
78 Build Thread
4Runner Build
sway bar
