#15 |
Active Member
Re: Brake booster install pics
LUV, the check valve holds vacuum in the booster, if the engine stops, you still have booster power for one stop....the hydroboost has an accumulator for that same reason, it's that gold colored 4" long can that sticks out of the h/b unit.
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() Gets More ChicksMy lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
| Bookmarks |
