Upgrading top end. Pull the engine out or not?
I will be changing heads and cam on my 69 c10 next week. I can't decide if I should pull the engine out or do it while it's in the truck? I am leaning toward pulling the engine out just to be easy on my back. Maybe I am getting old, because few years back I wouldn't even think about it. What's your prefference when doing top end on 67-72 truck? Pull it out or not?
Re: Upgrading top end. Pull the engine out or not?
Well, since its a fullsize, you've got pro's and cons of both.
Being its bigger vehicle, its easier to access all the bolts and mounts and such and makes the engine easier to pull out. But, then again, with all that room, you've got extra room to do the work with the motor in the truck still. Yanking the motor will probably be more work. But should be easier on your back. I've done head/cam swap on my v8 S-10 before with the motor still in. Wasnt worth it to me to pull the motor. |
67-72 Addict!
I don't think it's worth pulling the motor unless you are planning to detail the motor or take care of other things. I'm planning on swapping heads soon with the motor still in. My cam swap did not require pulling the motor either.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Save your back !! Pull the motor. It will provide a perfect time to detail not only the engine but the engine bay as well. Jim
I would pull the motor and put it on an engine stand and do whatever is that you want to do to it then drop it back in...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
me honestly.......i would pull the motor. its easy to get them out and back in. it would be better to have it sitting on a stand to do what you need to do.
![]() ![]() cardomain page: http://www.cardomain.com/id/DmestcDisturbnce |
Car Knocker
With an impact and a knowledge of the truck. You can pull and engine and trans out in less than an hour. Good time to change tranny fluid and filter while its out. I say pull it if you have an engine stand.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
It's a catastrophic success.
![]() Join Date: Jan 2003
How many miles are on it?They say an upper rebuild on a high mileage motor will cause premature bearing failure because of the increased compression.
I know its hard to know where to stop when doing a partial repair but if your gonna pull it out anyway whats a few more dollars.LOL |
After taking radiator and everything on the front I simply ran out of room in the garage. I didn't want to leave anything outside. My neighbour had a battery stolen overnight. So I just pulled the heads. I am almost done. I am taking a break with a few cold ones and will work on it later tonight.
Is that a pontiac engine? Hence the name Pont406?
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
