10-31-2008, 12:48 PM | #1 |
86 C10
How do You extend
the rubber fuel lines,ones from the fuel tank, what is the best way to extend them? I'm thinking of cutting them and placing some sort or pipe or fuel line inside and using hose clamps (don't know if it makes sense) but would it leak?
Thanks.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
10-31-2008, 01:02 PM | #2 |
Robert Olson Transport
Re: How do You extend
they sell fuel lines in the auto parts store you can get.. id try to keep it as much steel as you can tho.. you can use unions to joun steel lines
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
11-01-2008, 12:05 AM | #3 |
on the few lines that i've kinked while screwing around with them, I've just cut the metal line on either side of the kink with a pipe cutter and relaced the section with a piece of rubber fuel line that you can buy at parts stores and put clamps on it. Never had a leak yet
11-02-2008, 12:18 AM | #4 | |
86 C10
11-02-2008, 06:47 AM | #5 |
dang its hot
look closely at sources of rub through and ignition!!! you don't want to fix cheaply the fuel system! buy the tube bender if kinking is a problem
11-02-2008, 04:30 PM | #6 |
It'd be alot cooler if you did
I always use two hose clamps just in case, but no it won't leak. I've done this several times.
11-04-2008, 12:23 AM | #7 |
86 C10
thanks thats what i wanted to hear!!
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold Last edited by baggedcten; 11-04-2008 at 12:24 AM. Reason: spelling |
