Old 11-04-2008, 08:36 AM   #26
68Stepbed
68Stepbed's Avatar
Re: Calling All 383ci Trucks
VDOG, you won't have to change your gears with a 383. The 3.08's will be fine as long as you don't get too radical with the engine and cam selection.
My suggestion would be this:
383 with Vortec heads, an RV cam, NO bigger than a 600 cfm carb, a dual plane intake, a good HEI ignition system, and a decent set of headers.
This combo should be very similar to the GM crate engine noted above, but alot less money. It would have great street manners with a smooth idle and still provide about 300-320 hp which is plenty enough to smoke tires when you want.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-04-2008, 08:39 AM   #27
Gray Ghost
Gray Ghost's Avatar
I had my 350 built for $1100 here locally & saved a ton of money! Mine gets 12mpg without OD [TH350 soon to be changed to a 700r4]. The motor is a very strong one that has a mild cam [pulls from 1000 rpm for towing]. The tranny is rebuilt as well.
The 383 will be much more fun, but I think for your application a stout 350 is all you really need.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 11-04-2008, 08:40 AM   #28
Is it the longer stroke makes it less suited for highway and you`ll get less miles argument?It`s not that significant of a stroke over the 350 to matter there.It`s not like it`s in a whole new rpm range.Plus,you`ll get better power from lower rpms so that makes up for the extra travel on the piston at a given rpm.
Old 11-04-2008, 08:53 AM   #29
mrein3
mrein3's Avatar
A 383 is a no-brainer in my opinion if you are sticking with a small block. You can build a 383 for ALMOST the same cost as a 350 since the 383 parts are so common now. I managed to get mine done for a touch over $1200. I used a 350 block out of a Monte I used up years ago. My rebuilder had a 400 crank he was saving for such a project. The rods are out of the Monte. The rebuild kit with the correct pistons was +/- $20 of the cost of a 350 kit. If you have a small block in your truck now EVERYTHING else is the same on the truck. (You state you have a 283 so you're good to go).
I run mine in a 4x4 with 3.73 gears. The only thing I would (actually am going to) change is the tranny. Right now I run a th350. The rpms are a tad high on the highway in the 70 mph zones. A well built 700r4 would be just the ticket and is on my list. With 3.08 gears you will be fine with a th350. In fact I read on these pages that people with 3.08 gears got worse mileage after switching to a tranny with OD.
For me the benefits of the 383 far outweighed what I could get out of a 350. I pull my boat a lot. I pull stuff like docks and boat lifts out of the mud bottom of the lake. You really notice the difference. I just stuck a snow plow on the front of it for the winter. We'll see how that goes.
If you're just going to drive around the city, nevermind. Get a 350.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-04-2008, 12:43 PM   #30
VDOG
Grand PooBaa Member
VDOG's Avatar
The parts you mention above is what I had planed for a 350. About 9 to 5 compression with Vortec heads, RV cam and add my HEI and Headers with a Vortec Intake and my 600 Carb. I figured that would be a good strong motor with ok gas mileage, and decent power.
VDOG is offline   Reply With Quote
Old 11-04-2008, 12:48 PM   #31
VDOG
Grand PooBaa Member
VDOG's Avatar
See im not pulling anything, car, boat nothing like that. And Im going to have to disagree with you on the revs of the 3:08 gears. On the freeway at 65mph im taching out at 4000 rpms with those 3:08's and TH350 trans.
Old 11-04-2008, 12:55 PM   #32
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by chevy29267truck View Post
283 327 350 are good chevy engines you take a chevy 283 and 327 engine and have a chevy 302 DZ engine if you want too
You know how the Mopar guys are, I told my friend anything I buy for my 283 will work on a 350 block, I think he is stuck on the 283, a small number so he does not think its worth repairing. My motor is all roller, been pulling strong for 10 years now. I appreciate all the input you guys have giving me, thus why I stay here for advice.
Old 11-04-2008, 01:06 PM   #33
WorkinLonghorn
WorkinLonghorn's Avatar
VDOG, there's something way off here. I don't have time this morning to figure it out but you are either in 2nd gear or you have a MUCH lower gear in the diff.
I have 3.73 and at 65 I'm at 2600 or so.
My last truck had 3.07 rear (33" tires) and it cruised at 60 at 1875 RPM.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 11-04-2008, 01:15 PM   #34
prg machine
prg machine's Avatar
Originally Posted by Ricks1971 View Post
Build a sbc 400! make sure that its a 509 casting block. more tork and power than a 383.
The 400 is not the same engine as a 383. The topic is 383s and for a darn good reason.....................very fool proof way to achieve low end with a fool proof method........................how much you do to the engine in regards to aspiration and ignition will determine what you achieve in power.
A good streetable engine can be put together without a whole lot of cash outlay.
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 11-04-2008, 01:35 PM   #35
Slik69
All I can say is prior to buying my 69, I often used my dad's 70 which has a 383.. and the one thing I dreaded the most about using his truck was replacing the gas I used. Sometimes the cost of replacing gas outweighed the use. 'Seriously'. He also has a Victor Jr. Intake a Carter 850 AFB carb, and Dart heads. Way too much IMO. I think if he changed carb and intake he would see an improvement in gas mileage.. but not much, but I think it will lose some zip.
This motor was built for an El Camino, but was quickly taken out because the car would not go in a straight line at any speed. It was simply too much motor for a light car. Put in in a 3/4 truck loads of difference on behavior. Stall is something you'll have to add also. Why add the power if you can't get it to the ground. His truck is nice and you can hear it coming and going.. but I want something different for my truck. I will be going with a mild-stout 350. It drives plenty good right now with a very tired 327 in it.. so a freshly built 350 will be that much better. It's a 1/2 ton truck and only weighs 3780.. that's pretty light for a truck. Has a TH350 behind it and gets decent gas mileage since switching over to HEI.
My dad still has the truck and I can't tell you the last time it was driven.. He calls it the beast. He too complains about the gas and says "that's why it's sitting there". He'll be making some changes soon that I mentioned above.. but the base will still be 383.
Bottom line, it's your truck so you can do what you want to do. If you can afford to gas it and go COMFORTABLy,, then build the 383 and drive it like you stole it. If you want a better balance of the two, then 350. I'm going 350 route with my build. Will not be towing anything either, but in the event I do, I am confident the 350 will be able to handle it. Once you get up to speed the stress is pretty much off the motor anyways. I will be going with a 200/700, or leaving the TH350 in I already have. Doing this research now. Folks seem to like the TH350 over the overdrives. Anyone know why?
Slik69 is offline   Reply With Quote
Old 11-04-2008, 01:37 PM   #36
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok FT size 15x8 255x60x15 26 1/2 tall tires in the back
RT size 275x60x15 27 1/2 tall tires on 3:08 gears and Th 350 trans with a 283ci motor. 4000 might be high but its in the high 3's easy
Old 11-04-2008, 01:38 PM   #37
mrein3
mrein3's Avatar
I agree. Something is way off in your calculations or actual readings. My engine has never seen 4000 rpms and I drive down the slab in a 70mph zone all the time.
I didn't write it down but the last time I was out in a 70 mph zone, I think I was taching around 3200 rpms.
Again I have 3.73 rear end gears and 28" tall tires. Assuming I'm seeing 3200 rpms in my truck at 70 mph, 3.08s with 28" tall tires should be seeing approximately 20% lower R's or 2500 - 2600 R's.
'72 Malibu hard top
Center City, MN
Old 11-04-2008, 01:39 PM   #38
mrein3
mrein3's Avatar
Ha! We posted at almost the same time.
'72 Malibu hard top
Center City, MN
Old 11-04-2008, 02:53 PM   #39
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I agree. I have 275/60-15 tires on mine with fairly new 3.73 gears. my truck runs in the low 3k rpm range at 60-65.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-04-2008, 03:13 PM   #40
Blackbird66
Sound more like a 4.11 gear. I too have 275/60r15 with 3.73, and I'm spinning 3-3.5k on the interstate. As far as gas milage........I've run a stock 307 2bl hopped up 283 4bl, and now a gmpp 350 ho. All three motors got nearly identical gas milage on the interstate.
Blackbird66 is offline   Reply With Quote
Old 11-04-2008, 03:25 PM   #41
70rs/ss
70rs/ss's Avatar
A vortec block and heads (roller cammed) can be found for a core price ($100-150) and it'll get you a set of heads, as well as a vortec roller cammed block, buy a balanced 383 kit that'll drop into the block for like $8-900 and all you'll need is a bore/hone and some small reliefs in the block for clearance. Get a mild roller cam and use the factory roller lifters, etc and the heads will ahndle up to .500 lift/flow so a .480-.500 lift cam would be fun smaller is OK and then you'll have an honest 350-400hp and over 400lb/ft of torq. With a 3.08 and a th350 you should be able to smoke em for as long as you want, get decent MPH and MPG on long road trips and it'll last forever under 6K RPM, so why not build one?? With a complete kit, you can do this for about $1500-1800 tops and as mrein3 said it can be done even cheaper, but the piecing it together can get pricey for a balance, whereas the balanced kits come ready to use, so a little more $$$ = less work and headaches?? Do I have one, yep, and it'll be north of the 450hp range with 500lb/ft of torq and a HUGE cam, but so what it'll outrun most anything I come across and I'll be OK with frequent stops for premium fuel, cause the smiles per/gallon is all I am worried about!!
70rs/ss is offline   Reply With Quote
Old 11-04-2008, 04:44 PM   #42
WorkinLonghorn
70rs/ss; I'm sure this has been beaten to death elsewhere but if he uses Vortec heads, will his accessories bolt up or not?
Also he'll need vortec intake.
Old 11-04-2008, 05:35 PM   #43
68Stepbed
68Stepbed's Avatar
I'm gonna have to agree about the numbers being off on your calculations. I have a TH350 and 3.73 gears and I turn about 3350 at 70. It would turn 2500 at 70 with 3.07 gears. I'm also thinking you have 4.11 gears.
How did you determine you have 3.08's?
Check your calculations here.
Matt
Old 11-04-2008, 07:44 PM   #44
VDOG
Grand PooBaa Member
VDOG's Avatar
The original engine for this truck was a 305, 2bbl carb. Also when I removed the gears to install 3:73s I had the numbers refference, and from talking to a few people here, I found out they were 3:08's.
I also learned the hard way that 3:73's out of a 1970 6cyl 12 bolt truck will not fit in a 69 12 bolt truck. Would not line up and when installed one axel went in further then the other. (See attached inner drum pic.)
Notice how the lip of the drum on one side has a lip while the other side is flush.
So the guy rebuilt it to the stock gears, 3:08's
Old 11-04-2008, 08:00 PM   #45
68GMCCustom
isn't that because there are 2 carriers for truck 12 bolts....1 for 3.73 down...and one for 3.73 up? ...or something like that.
Kurt -
Old 11-04-2008, 08:30 PM   #46
VDOG
Grand PooBaa Member
VDOG's Avatar
I cant remember what the gears were, either 3:55's or 3:73's, one of the gurus here can tell me for sure because I forgot. The reason for the difference in the spacing, 1970 rearend and axel tubes are longer.
1970 uses different length axels.
Old 11-05-2008, 09:29 AM   #47
68Stepbed
68Stepbed's Avatar
There is a difference between the 3 and 4 series carriers. It has nothing to do with year models. The pre-70 rearends are shorter in width and do require slightly shorter axles than 70-72 model rear axles.
The reason your 3.73 gears(which are considered in the 4 series: 3.73- numerically higher gears) wouldn't fit is because you were trying to install them into a 3 series: 3.42-lower numerically gears carrier.
The thickness of the 3 and 4 series ring gears are different. Most gear companies make gears to fit either carrier. You also could've just installed a ring gear spacer to install your 3.73 gears into your 3.08 carrier.
Something is still wrong somewhere if your turning almost 4K rpm at 65-70 mph. Is your tach reading correct?
Matt
Old 11-05-2008, 10:43 AM   #48
Heavy Evy
born to lose
Heavy Evy's Avatar
I drive my 383 powered 71 C20 everyday and before the race track closed for the season I was drag racing it almost every weekend and drove it to work the next night with no problems. I have taken it on long cruises and never had a problem. On the freeway with a th350 and 4.10's its turning about 3800-4000 rpm at 65-70 miles per hour. I would say build a stroker you will not regret it.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 11-05-2008, 01:07 PM   #49
prg machine
I get 14 mpg on super when I don't play
383 .040 over
Old 11-05-2008, 01:17 PM   #50
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks guys. Now what im reading is im ok with my th350 trans but none of you are running 3:08's. I see 3:73's are the perfered gear for a 383 motor.
Which since it was rebuilt last year, I dont want to spend more money to change it. Again not opposed to the 383, and long as I cant get the right combination to work with what I already have installed.
