Moderator
![]() Join Date: Jun 2008
Sending Unit part # 6429115 ...will it work on a 1970?
I am looking at getting an NOS sending Unit part # 6429115 ...will it work on a 1970? It says it's for a 1972 Chevy truck Are they the same?
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#2 | |
Sierra Grande Club
Re: Sending Unit part # 6429115 ...will it work on a 1970?
![]() sorry, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Does the sending unit you are looking at have a single outlet or does it have two outlets?
The difference is going to be in the hookups of the gas line. The 70 will have a single outlet, either a 5/16" female fitting or a 3/8" female fitting. The 72's that I have seen have two lines on the sending unit and are connected using fuel hose. Chances are that it will not be a direct swap out but could be made to work as the ohm output will be the same. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Moderator
Thanks, Jim.
