I need help with my doors
can manual doors be used instead of electrical doors. Had to replace the doors and now stuck with the manuals. If they will work I know I would have to cut out a section of the door to fit in the window motor.... right? or Im I wrong and cant use these doors at all? Help!
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
yeller
Re: I need help with my doors
As long as the doors are 77+, then you can use manual doors and retro-fit your PW/PL stuff into them. As noted, you will have to cut a hole for the wiring.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 11-06-2008 at 03:09 PM. |
I dont know what year they came off of but I know i have to make the holes for the wires and the hole on the sides to fit the motor assembly but Is there anything else besides that? I did feel the window bracket inside so I might be able to use them
#4 | |
Parts and more parts
Are you sure about the hole for fitting the motor in. I think that most doors are the same, with the exception of the wiring hole. |
yeller
Yes, all 77-87 doors are the same regardless if they came with power options or not. The earlier 73-76 doors did not come with power options bacause they would simply not fit...hence the redesign in 77.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
ill get home and take a pic of them so you can see what im talking about. So far thank you all.
I got the problem resolved..... thank you guys
