Old 11-06-2008, 09:20 PM   #1
chevymotocross
chevymotocross's Avatar
Best aftermarket sway bar?
I'm looking to buy a sway bar for my 87 2wd silverado swb. It came with no sway bar from factory. Summit Racing sells sway bars from Belltech, Addco, and Hellwig. One brand better than the others? Any personal reviews?
Will these aftermarket sway bars bolt to my truck since it came with no factory sway bar? Or, must I also buy factory brackets to mount these?
Truck is at stock height now. I am eventually going to give it a mild suspension drop, but for now, I want some better cornering!
chevymotocross is offline   Reply With Quote
Old 11-06-2008, 11:19 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Best aftermarket sway bar?
Always had good luck with the hellwig brand myself
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-06-2008, 11:31 PM   #3
Knight383
Knight383's Avatar
My Blazer come with no factory sway bar and I know If there are two holes in the lower control arms thats where the sway bar installs. Even if it didn't come factory now Summit is where I where I get me parts and there are diffent bends in the sway bars I got an Addco and the bends were wrong so I have to send it back and get the right one.
Knight383 is offline   Reply With Quote
Old 11-07-2008, 03:01 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I ordered the Addco one from Summit. Their computer lists the wrong one and it doesn't fit at all. They don't know which part number is the right one. I just had this happen to me about a month or two ago, so they probably did not fix the problem. I ended up with the Bell Tech one and it is much nicer anyway.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-07-2008, 07:51 AM   #5
chevymotocross
Thanks for the info on the Addco. After re-checking the summit website, Addco states that their sway bar only works on trucks with a factory sway bar already installed. With that information, their sway bar wouldn't have worked anyways.
I think the belltech one looks "cooler" than the hellwig, both are about the same price too.
Old 11-07-2008, 10:52 AM   #6
smashingchuck
here a pic of my Bell Tech sway bar installed. I made my own mounts and welded them to the control arms, as opposed to drilling holes in the control arms like the directions say.... wouldn't have worked anyway with my tubulars, but you could do the same thing on some stockers.
78 Build Thread
4Runner Build
