Why does it taste purple?
Re: For Thoese Doing Disk Brakes. 60-66
w00t,my buddy blew the engine in his 79 chevy and guess what,I'm buying it for a disc brake swap for 100 bones.Now my question is,the 79 has leaf springs in the rear like my 66 gmc does.I assume I could straight swap the entire axle assembly right?I sure as hell hope so lol
One day...
![]() Join Date: Apr 2008
Yeah that would be the easiest way.
I've been following this thread from the beginning and just completed installing the complete frontend from a 78 GMC 1/2 ton to a 62 frame.
For me it was far less work to change everything over including the crossmember. I think I had to drill maybe 2 new holes in the 62 frame rails to get everything bolted in. I might mention, the frame rails on the 62 are shorter than the 78 so I had to fab a little to use the 78 motor mounts. I fabricated a mounting bracket to mount the powersteering gear from the 78 to the 62 frame. I installed a 4-link posi from a 70 Caprice on the same frame, which was a lot more work than the frontend. I'll attach pics in a few days. Great site, thanks for the tips. |
#4 | |
I'm just glad to be here!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
