Old 11-07-2008, 10:29 AM   #1
Heavy Evy
born to lose
Heavy Evy's Avatar
Door latch problems
Iam having a hard time getting my door to shut tight. I have tried taken out and redoing the shims but nothing has worked, Im wondering if the latch just needs to be replaced. Any info would be greatly apperciated.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 11-07-2008, 10:48 AM   #2
OrangeCrush1970
OrangeCrush1970's Avatar
Re: Door latch problems
Sorry...I needed to jump on the thread, Im having the same issue.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 11-07-2008, 12:01 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Not sure which shims you are referring to, but I adjusted mine by loosening the door bracket and tapping in until I got it to shut right.
Be aware that if you have a worn or torn rubber door seal it will affect the way it shuts. I had to readjust mine when I bought new push on seals from GMC Pauls.
68gmsee is offline   Reply With Quote
Old 11-07-2008, 02:20 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
The striker (pictured above) could also be in "too far" and only letting the door close to the safety catch before it contacts the rubber seal....
LockDoc
Leon
Old 11-08-2008, 05:09 PM   #5
Heavy Evy
born to lose
Heavy Evy's Avatar
The shims Iam referring to might not even be called shims but they are the little strips of metal between the striker and the cab the 4 bolts hold them on. I never thought about my door seals affecting the way the door shuts, I have just had this problem with this truck since my dad bought back in 90.
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 11-09-2008, 03:50 AM   #6
bagged70
My fix to this problem was that i instaled bearclaw latches
bagged70 is offline   Reply With Quote
Old 11-09-2008, 04:42 AM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
I replaced the rubber bumpers and the latch to fix the problem.
