Old 11-08-2008, 07:59 PM   #1
aboyer
Adam B
700r4, Slow going into Drive
I have just recently installed a rebuilt 700r4 into my truck. I bought the transmission off of a guy that rebuilds transmissions on the side.
Upon running it for the first time, I installed 8 quarts of transmission fluid and it reads that is is properly filled. I have also ran through the gears with the rear end jacked up.
I have gone on various "test runs" and the truck goes great into reverse without any delays. However, when I then shift it into drive, it takes about 4-5 seconds before the truck wants to goes into drive. Once it is in drive, it shifts properly and seems to work fine. It has had this same issue since the install.
I have ran out of ideas to look at, and not sure what direction to look into. My truck as a stock 350sb motor as well. Any help would be appreciated.
Thanks,
Adam
aboyer is offline   Reply With Quote
Old 11-08-2008, 08:50 PM   #2
sweet70beast
sweet70beast's Avatar
Re: 700r4, Slow going into Drive
Was the trans and torque converter dry when installed? Seems to me that 700r4s hold 12-13 quarts when totally dry.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 11-08-2008, 11:12 PM   #3
aboyer
Adam B
Before I installed it, I did fill up the torque converter with transmission fluid. It almost seems like the transmission might need more fluid, but I am not sure if this is a good route to take????
Old 11-08-2008, 11:20 PM   #4
uno67
uno67's Avatar
complete fill of 700r4 10.6 quarts
uno67 is offline   Reply With Quote
Old 11-09-2008, 06:50 AM   #5
smoky02
Location: Sunny, Florida, some might call it South Alabama
You have the right amount of fluid. Me and my dad just installed a 700R4in my truck. It was dry when we got it, I put about 6 in the TC, and 8in the transmission. But mine drops right into gear when i put it in drive though.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 11-09-2008, 08:31 AM   #6
big_al_71
big_al_71's Avatar
Why not just drive it to the guy and let him figure it out? I would think that the valve body might need to be looked at....
Good luck...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
