10-30-2008, 09:14 AM | #26 |
Re: Grrrrrrr... cant trust anyone
that's what I think too. when I had my plugs set at .035, it was dog slow, and had really bad gas mileage. when I asked at o'reilly what the plug gap should be, they said it should be set at .060. i also looked on the internet, and most people said to set it at .045. so i set it at .045. it runs better, and has better gas mileage. next time, i am going to try it at .060, just to see if i see a difference.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
10-30-2008, 09:36 AM | #27 | |
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
10-30-2008, 11:51 AM | #28 |
The jump out from under the brakes comment leads me toward not hooking up the vacuum for the booster. Even though that should be pretty obvios?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
10-30-2008, 12:02 PM | #29 |
Hot Rods For Life
Really it would be nice if we had guys here on the board we could trust to do work on our trucks. Not for free but just trustworthy folks from your area.
That is all. Carry on. |
10-30-2008, 02:42 PM | #30 |
Under Construction
sounds logical ZUMO. your down 287 from me....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-30-2008 at 02:43 PM. |
10-30-2008, 05:25 PM | #31 |
I wish I was a cowboy
Hey! I resent that! I'm a network engineer, and I'm a gearhead! J/K on the resentment.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
10-30-2008, 05:30 PM | #32 |
Probably not your issue, but I replaced my vacuum advance unit on the dizzy awhile back as I replaced rotor/cap/wires/etc....it lasted 2 months and started leaking [air]. Took it back to the parts place, they replaced for free, runs beautiful now, 'cept for the oil leak.
10-30-2008, 06:11 PM | #33 |
Engine n00b
10-30-2008, 06:13 PM | #34 | |
Engine n00b
Our consulting firm has 3 guys with classics out of 50 people. Not bad. a 70's stang, an early 60's stang, and my C10. Needs more. |
10-30-2008, 06:16 PM | #35 |
yeah, it probably is bad plugs or something, I actually broke one of my sparkplugs without realizing it while doing a valve lash adjustment, truck ran bad and I even backed out my adjustments before finding the broken plug....
10-30-2008, 08:12 PM | #36 |
Restoration Desperation
off the subject...Roger, your avatar is outstanding
RD |
10-30-2008, 08:27 PM | #37 |
10-31-2008, 10:34 AM | #38 |
I ONLY checked your personal album to make sure you were correct.. you are.. it only took me 20 minutes to find 'em too... just trying to maintain self confirmation of my screen name.... I still do! I think I liked the truck too.. not sure though... was it green?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
11-01-2008, 05:07 AM | #39 | |
Neighborhood Pickle Slinger
Took me a couple seconds to find them.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
11-10-2008, 12:59 AM | #40 |
Hand Crafted C-10
If you haven't solved this yet...
in a small nutshell... Re-gap the plugs to .045. Make sure firing order is correct and wires cross correctly...look under the hood for mishaps when it's dark outside...you will see arching if there's a problem. Since they gapped the plugs (wrongly) for an HEI, make sure they used the correct plugs for your HEI distributor. Look for missing/broken/un-plugged-in vacuum lines...spray carb cleaner at likely suspects when running to see if the engine changes tone. Find the mechanic and get a list of what he messed with. Get them to re-emburse your first bill for all the trouble you have gone through. That's the only way we can get these irresponsible shops off the street. This could always be a fluke, but I doubt it. just my 2 bucks... Last edited by ETsC10; 11-10-2008 at 01:33 AM. |
11-10-2008, 01:11 AM | #41 |
Was what green? Looked blond to me.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
