Old 11-09-2008, 04:21 PM   #1
jollyroger040
jollyroger040's Avatar
rearend ratio on a 1976 C10
I have a 76 step side that originally came with a 350 and 3 speed manual. I just went to check the rearend ratio and after turning the wheel one complete turn, the driveshaft only turned 1.75 times. Am I doing something wrong or do I have a 1.75:1 gear ratio in the rearend? Never heard of such a ratio.
jollyroger040 is offline   Reply With Quote
Old 11-09-2008, 06:19 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: rearend ratio on a 1976 C10
If you hold one tire still & spin the other, you have to take your number X 2 because of the spider gears.
1.75
X 2
3.50
I think the ratio offered for that year closest to your count was 3.73, so I'd bet your count is actually a "hair over" 1.75
And, welcome to the board!
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 11-09-2008, 06:53 PM   #3
jollyroger040
Hey guys I do appreciate your help both worked ! Thanx Ed
Old 11-09-2008, 06:55 PM   #4
msgross
msgross's Avatar
pull the cover off (drain oil) look at the numbers on the ring gear... 41:11 is 41 divided by 11 = 3.727272 or 3.73
raplace seal and oil and you have a 100% accurate idea and a serviced rear diff...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-09-2008, 07:14 PM   #5
jollyroger040
Thanx again we got er solved with your help its a 3:42
Old 11-09-2008, 09:48 PM   #6
mister honey
That sounds right...my '76 C10 with 350/3 speed came with a 3.42 gear set.
Mike
mister honey is offline   Reply With Quote
Old 11-10-2008, 03:03 PM   #7
73CheyenneSuper20
73CheyenneSuper20's Avatar
I was wondering what mine is, I just didn't want to do that just yet, too many other leaks to fix first.
'71 C25 Camper Special, 402, TH400, Longbed, Power Loc axle, Figuring out the rest of the details....
'10 Dodge Charger SXT - DD
'91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!)
73CheyenneSuper20 is offline   Reply With Quote
Old 11-10-2008, 06:19 PM   #8
msgross
msgross's Avatar
If you do that you can also pull your axles and put new seals in the end of them, then it snowballs with brakes, bearings and so on...
The Garage:
