Old 11-12-2008, 09:44 PM   #1
68chevycst
68chevycst's Avatar
Hedman headers
I just purchased a set of hedman elite headers for my 70 chevy cst short box 2 wheel drive 1/2 ton and they don't fit. The headers hit the bottom side of the frame on both sides. The motor is a stock SBC 350 and I have a 700r4. The motor mounts are brand new too. Hedman says that they have never heard of this before... I have a 68 chevy with the same set up and the problem exists with the hedman headers I ordered for it too. Has anyone else had this problem?
68chevycst is offline   Reply With Quote
Old 11-12-2008, 09:48 PM   #2
bdydrp97s10
bdydrp97s10's Avatar
Re: Hedman headers
i had a problem with my hedmans hitting my motor mounts..
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 11-12-2008, 09:49 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: Hedman headers
Welcome to the site! I have heard good and bad about Hedman. I have Hooker Super Comps and they fit good
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-12-2008, 11:46 PM   #4
c-10ss
Re: Hedman headers
mine don't hit at all and have my motor 5 inches back from stock and custom motor mounts, even when the motor was in stock loaction they were fine
c-10ss is offline   Reply With Quote
Old 11-13-2008, 12:26 AM   #5
67ZL1
Re: Hedman headers
I am having the same problem with right now, except I have the husler series. I waited for almost 3 months for them to get made, spent lots of cash on them, and now frustrated
67ZL1 is offline   Reply With Quote
Old 11-13-2008, 09:13 AM   #6
70GMCer
70GMCer's Avatar
Re: Hedman headers
I ended up beating the hell out of 2 tubes so that they would fit. I would have sent them back, had I not had them coating by Jet Hot. I made the mistake of not test fitting them before having them coated. So, if you can, send them back....."Hedman blows".
I would rather take an old kids swing set or use some 1 1/2" black plumbing pipe with pipe elbows and make my own up before ever using another set of Hedman headers.
All that room in that engine bay, and they can't get them to fit. Unbelievable!! JMO though
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-13-2008, 09:32 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Hedman headers
Which part # headers are you talking about? Also,... are these full length headers or "shorty" headers? I was thinking about using the elite version of the Chevelle "shorty" headers. Also is your sbc in the stock location or the I-6 location?
Keith
Convert to disc brakes.
Old 11-13-2008, 03:39 PM   #8
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Re: Hedman headers
Im running the full length elites on a 350. Very close to frame on drivers side but not touching. Had several pairs over the years with no problems.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 11-14-2008, 01:42 AM   #9
68chevycst
68chevycst's Avatar
Re: Hedman headers
THat sucks! Have you called hedman?
Old 11-14-2008, 01:44 AM   #10
68chevycst
68chevycst's Avatar
Re: Hedman headers
I'm going to try and send them back. Thanks
Old 11-14-2008, 01:47 AM   #11
68chevycst
68chevycst's Avatar
Re: Hedman headers
They are in the stock forward location. The part number is 69090. They are full length headers.
