![]() Join Date: Dec 2000
Hey Guys,
I have a '79 Blazer w/ 400 SB, TH-400, NP-203, A/C, P/S, P/B, Tach, P/W, P/L, and oh yeah, a rusted top, quarters, etc. But I also have an' 83 C-10 P/U w/ a good body, so I'm thinking of swapping the newer cab/front clip onto the Blazer chassis. Anyone know of any problems that may arise? I'm doing away w/ the A/C, P/W, P/L in the process and will utilize a small flatbed. Thanks! Doc ------------------ '70 Sub C-10 350/TH-350/3.73 12-bolt Black-on-black 15x8 Rallys w/ 275/60/15 Soon to be lowered....
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
I think they have dif. frames. I had a 1984 blazer and the wheel base was shorter/longer then the swb truck. I really don't remember but I think there is a dif.
2001 Camaro SS 335hp (for now) 2000 GMC P/U |
shepherm,
I know the wheelbases are different, that's why I said that I was going to use a small flat-bed behind the cab. The Blazer frame is much shorter than even the SWB trucks, but I'm going to use this Blazer-hybris off-road mainly. Thanks! Doc
Strongman Garage
![]() Join Date: Apr 2000
try www.coloradok5.com
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
Oh,you can't buy that new
DOC, there are no REAL problems with this as you are changing cab& clip which makes the swap much easier. there is a slight mod to the front of the frame so you can mount the newer style bumper. Once you look at both you'll be able to figure it out.An air whizzer or sawzall will do it.may have to drill a hole or two , no biggy,DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
Thanks Crossy!!
Doc
