![]() Join Date: Dec 1999
Putting a 454 in a 2wd 350 powered 79 Blazer also going to use headers.I have factory 73 Big Block Mounts also have all the correct brackets pulleys.Anyone know of any other problems i should look foward to,or any extra holes i may need to drill?Hoping to get this done before it goes in to get painted Monday.Thanks
------------------ 69 GMC SWB 402t400 daily beater,. 67 GMC SWB 468t400 Project Go Fast 79 Blazer 2wd 350t350(awaiting its heart transplant) 1962 BelAir SW Project-currently 454t350. 99 Nissan Frontier 4cyl,5spd,-hey it gets good gas mileage,and the AC is COLD and its reliable!!!! Located In Casa Grande,AZ(48 miles South of Phoenix) WANTED 62-64 409 Engine,79 Chevy Blazer or P/U Door Panels,Dash Pad,Blazer Tailgate window,71-72 Leaf Spring Rearends(need 2)any ratio Vintage Aluminum BBC valve covers,Crossram intakes,Finned Aluminum oil pans,63-63 Impala AT tilt column.Buy Sell or trade. |
![]() Join Date: Sep 2000
The fan shroud is diferent.the wire harnes is to but the small block one should work. But looks like your all set.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
its all about the +6 inches
Yeah...watch your fingers..those things are heavy!!!
------------------ The hot rod; a'69 G.M.C. Short/Fleet. 350 W/a heluva cam and nice stance. Trying to clean up the left over damage from the Dope-Smokin-Old-Man. See it at http://geocities.com/andys_69_gmc/ I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Check out my Longhorn site at http://geocities.com/MotorCity/Flats/8752/ Need to pick up the one ton Longhorn with a 350/350 here soon, thanks every one! ![]() If you need a pic posted, e-mail me at longhornmail@yahoo.com |
yeller
I thought the motor mounts for small and big chevys were the same. I am doing the same swap into my swb 1/2 ton and never thought twice about the mounts, am I wrong?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
www.73-87chevytrucks.com
SBC motor mounts will work. I am using them on mine. The fan shroud will be fine too. It will be a bolt in.
------------------ Chris Lucas 1973 Chevy C-10 1975 Chevy Silverado Captkaos Customs
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Captkaos-do you have headers on yours,according to the header manufacturer BB frame mounts are required,i dont see why it would matter but just want to be sure.
Yes I have headders on mine. Who is the manufacturer?
May I give a suggestion? They are high, but they will give you ground clearance. http://www.sandersonheaders.com 3/4 length Chevelle headers. I will be switching to these. ------------------ Chris Lucas 1973 Chevy C-10 1975 Chevy Silverado Captkaos Customs
It was Hooker Competitions,and i think Flowtech also said the same thing.But i dont know why it would matter.
