Old 02-22-2003, 10:33 PM   #1
Ron
Ron's Avatar
Ignition switch removal
How do you remove this switch on a 67 C-10? Are the switches the same from 67-72?
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 02-22-2003, 10:52 PM   #2
72c10
72c10's Avatar
iv seen this question before so if you do a search you should come up with something. I think that you have to stick a pin in the small hole and turn it though.
72c10 is offline   Reply With Quote
Old 02-22-2003, 11:04 PM   #3
70chevy
70chevy's Avatar
If you don't have the key
I am not sure what to do. I have cut with a die grinder on the back side, drilled holes in the front, and still don't have it out.
If you find out anything please let me know.
Ken Smith
99 C5 Torch Red Coupe
85 Chevy Candy Apple
70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump,
70chevy is offline   Reply With Quote
Old 02-23-2003, 12:26 AM   #4
dmurphy68
If you dont have the key the easy way is a set of vice grips. lock onto the front bezel. un plug you ing switch and start turning. you will evientualy get it off i was pissed off whit mine because i couls not get it out and that was sugested to me. Just rember things on these trucks can be replaced. not worth losing your mind over. I got a vew ing switch and tumbler for under 20 bucks and a new crome bezil on e-bay for 3 bucks so happy turrning
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 02-23-2003, 12:54 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The way to remove the tumbler is to stick the key in the ignition and turn it to the accessory possition. Take a paper clip or stiff wire and stick it in the small hole in the ignition face just above and to the left of the key. You will feel a spring inside it and you need to depress it. Then continue turning the ignition while depressing the spring to the left. After it turns then you should be able to pull the tumbler out with the key. Then unscrew the bezel from the ignition switch, unplug the wires from in back and remove the ignition. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
